SBC Harmonic Balancer Needed
Discussion in 'The Hokey Ass Message Board' started by Harrison, Dec 18, 2013.
  1. Harrison
    Harrison
    I need a balancer for my new crate 350. Unsure if I should go with a new GM 6272222 balancer for roughly $100 plus shipping or a new Dorman unit for half that much - shipped to my door.
    I'm not against spending the extra $$$ but if the Dorman part is basically the same thing..... I could stand to save $60-$70 right now. Seeing that it's a new crate motor from GM, I'm leaning towards just springing for the GM balancer though.
    Any thoughts?
    TIA, JH
  2. saltflats
    saltflats
    from Missouri
    If its just for a driver I would save the money.
  3. squirrel
    Is the GM part made in china, too?
  4. hotroddon
    hotroddon
    I have used the Dorman parts with no problems on a street car.
  5. do you think you really need an 8" balancer?
  6. Harrison
    Harrison
    I'm no mechanic. That's why I let someone that knew what they were doing build the engine. They recommended the 6272222 8" balancer.
    I try not to argue with people smarter than I am.
    (Which may explain why I don't get into many arguments. :eek:)
    JH
  7. indyjps
    indyjps
    Who knows how well the crate engine is balanced? Use the 8" and be sure you timing chain cover matches.
    I've never used a dorman balancer but have used plenty of their replacement parts. Never an issue. A new balancer has to be better than the crusty originals that a lot of people reuse.
  8. 1 Hotrod
    1 Hotrod
    from Wisconsin
    I have a new gm mallable balancer if your interested.
  9. KJSR
    KJSR
    from Utah
    You mean they wouldn't be the same quality?? :D
  10. rd martin
    rd martin
    from indiana
    do a little research on your balancer. there should be paper work with crate motor telling you what balancer to use. if not, google it. theres a bunch on there on gm crates. make sure you dont get a 8 inch 305 balancer, timing marks in wrong spot. just went threw all this. if you bought the 350/290 h.p. the timing mark will be very close to lining up with the keyway in the balancer, if not its for a 305.
  11. tubman
    tubman
    "I try not to argue with people smarter than I am.
    (Which may explain why I don't get into many arguments. :eek:)"
    Subtle.. I like it
  12. yngrodder
    yngrodder
    I've used the dorman balancer on my last three builds with no problems. Dorman actually has a lot of
    Improved oem items.. O'Reilly stocks the balancers and my local O'Reilly price match's so no shipping charges..
