SBC harmonic balancer question
Discussion in 'The Hokey Ass Message Board' started by PiLeDrIvEr, May 17, 2011.
  1. PiLeDrIvEr
    PiLeDrIvEr
    Swapping out my son's tired 307 for a later model 350. Had hoped to re-use all the components off the front of the 307, to include the power steering pump, but because the balancer on the 350 is a little bit larger the bracket won't fit in the mounting location near the bottom of the block. Can we swap the balancer too or would that be a bad idea?
    Thanks
    Alex
  2. badshifter
    badshifter
  3. squirrel
    can you trim the bracket?
  4. carcrazyjohn
    carcrazyjohn
    from trevose pa
    I wouldnt swap the balancer ...............Go to the junkyard and look for brackets ,,,If you can find Chevy trucks up to 87 All should be well
  5. oldsrocket
    oldsrocket
    If it's an internal balance engine and you use a balancer for internal balance you should be fine for typical street use. Some claim the 8"+ balancers accelerate more quickly. I haven't seen any back-up evidence myself. Just don't mix internal and external balance components.
    If you are going to twist it to high rpms, you should be balancing everything irregardless....
  6. Lobucrod
    Lobucrod
    Alliance Vendor
    from Texas
    For normal street use I'd swap out the balancer and never look back.
  7. gasshole
    gasshole
    from new jersey
    Swap it, just make sure the timing marks are the same.
  8. R Frederick
    R Frederick
    from illinois
    Just swapped a 327 from an Impala into a 57 Chev. and the 350 from the 57 into the Imp. with the same problem. We notched the power steering bracket of the Impala for the 350 balancer and will work just fine.
  9. PiLeDrIvEr
    PiLeDrIvEr
    Thanks for all the responses. Will try altering the bracket first.
