Technical SBC Harmonic Damper Questions
Discussion in 'The Hokey Ass Message Board' started by RaginPin3Appl3, Feb 12, 2026 at 10:44 AM.
  1. RaginPin3Appl3
    RaginPin3Appl3
    I stripped out the pulley bolt holes on my 283 last night while putting the pulleys back on. The harmonic balancer on the engine is almost certainly original. It's the riveted together 6" version (see below). The damper is press-fit on this engine, no crank bolt holding it on, and the crank is not tapped for one.
    I plan on eventually replacing the damper, since the rubber is almost certainly bad, but for now I plan to tap the 3 bolt holes t0 1/2", so I can get the car put back together.
    The question is: Are all internally balanced SBC dampers interchangeable? That is, can I take any old damper and press-fit it on this crank, or are later ones that use the bolt not able to be press-fit?
    I would rather not drill the crank at this time. Just want to know if I need a specific type of balancer that works with the 283 press-fitment.
  2. ididntdoit1960
    ididntdoit1960
    from Western MA
    You need the earlier style to match your timing tab and have the correct interference fit - nice to see your still at it and welcome back
    RaginPin3Appl3 likes this.
  3. RaginPin3Appl3
    RaginPin3Appl3
    Thank you, and good point about the timing tab. The damper on the engine is a 6", looks like those are pretty hard to come by. I'm not too worried about the timing marks on the balancer itself, since I can just put timing tape in the correct orientation.
  4. RaginPin3Appl3
    RaginPin3Appl3
  5. DDDenny
    Says 350, ?68/earlier or (appears to be 69/later) with offset timing mark/keyway.
    Worth a try but report back how it starts without changing distributor position.
  6. ididntdoit1960
    ididntdoit1960
    from Western MA
  7. brigrat
    brigrat
    from Wa.St.
    You need to find top dead center BEFORE you put any other balancer on it, especially something 50+ years old.
    Bentrodder likes this.
  8. RaginPin3Appl3
    RaginPin3Appl3
    The crank is keyed, so it really can only go on the one correct way. But yeah, I’ll make sure to account for any differences in timing marks on other dampers.
  9. Mr48chev
    What Brigrat is saying is that the rings on dampeners are known to move on the hub at times and the timing mark moves in turn.
    Personally I'd heli coil the dampener and used the correct size bolts so I didn't have to drill the holes in the pulley out ruining the pulley for use with correct size bolts.
    brigrat likes this.
  10. Jokester
    Jokester
    Drill the crank now! I've used the fat 350 balancers on several different 283/327 press fit style cranks. two of them flew off. The third one ate out the keyway and forced me to replace the crank. In comparison, threading the crank was cheap.
    my 2 cents
    .bjb
  11. Another vote for drilling and tapping crank. Remember crank should be forged
  12. DDDenny
    Pretty easy to get them drilled ****eyed without some sort of centering sleeve.
  13. There's people that sell a jig for drilling in car. One I looked at even had a channel to direct metal shavings away from the engine
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    just helicoil the holes on your balancer and put it back on....
