SBC head question
Discussion in 'The Hokey Ass Message Board' started by lippy, Feb 29, 2012.
  1. lippy
    lippy
    from Ks
    Howdy, I have a 327 for sale in the cl***ifieds. It's a 327 275 hp engine. It has double hump heads. I had a gentleman tell me he had an original 275 hp 327 in an Impala and it didn't have double hump 300 hp heads. I have never seen a 275 hp 327 that didn't have 1.94 double hump heads. Did some 275's have lo-po 327 heads? BTW, this is a 65 327-275. What say you old farts. :)
  2. burnout2614
    burnout2614
    I have never seen one that didn't have the hp heads HOWEVER the markings on the end of the casting were not the "usual" "camel humps". Chevrolet did not always use the "humps" to designate a hp head. Been my experience. peace
  3. brandon
    brandon
    I thought all 327'sof had humps. I do know a 327/275 hp intake is worth a tenth over a 220/283 intake on a stocker....lol how many different castings were there ?
  4. carcrazyjohn
    carcrazyjohn
    from trevose pa
    If memory serves me correct some had triangles and there was one more....
  5. Mrhuffy
    Mrhuffy
  6. Weasel
    Weasel
    I know almost nothing about Chevy SBCs but the 327 in my '36 Hupp had non double hump heads and was allegedly a truck engine with small 1.60 intake valves. It now sports 462 castings...
  7. HEATHEN
    HEATHEN
    from SIDNEY, NY
    250 hp 327s had the same heads as power pack 283s. 300 hp 327s and '66-'67 275 hp 327s had the "double hump" or "fuelie" heads.
  8. wheels777
    wheels777
    from York, PA
    275 or more HP had double hump. Less than 275 had single hump or triangle. '68 double humps had sensor hole in side of head.
  9. brandon
    brandon
    Goes back to the thing that every 327 is or was a fuelie vette motor and had 461's....lol
    Were low hp 520 castings?
  10. bobss396
    bobss396
    I had a '67 327 with the double-humped heads and also harvested a couple out of '68 Chevys that were the same deal, all 4BBL engines. You can go on forever with all the "experts" on this site and elsewhere.
    Either the guy wants the engine or not, or was trying to make a pointless point. If you were closer to me, I'd grab the damned thing just so HE couldn't have it. Something like that is legal tender in the hot rod community.
    Bob
  11. 3wLarry
    3wLarry
    from Owasso, Ok
    I had an original 1965 engine 327/250hp with double hump heads that I used in my 3w coupe. I have out in the shop right now a set of 1966 327/275hp heads and a set of 1967 327/275hp heads. They are all double hump with no holes in the front of the head. They are all 1.94 intake and 1.50 exhaust.
    kidcampbell71 likes this.
  12. rustang
    rustang
    What are the head numbers on the 275 hp head? Are they still a 461 casting?
    Tom
  13. A Rodder
    A Rodder
    My 63 impala ran a 1965 275 hp 327, it had double hump heads.
  14. HEATHEN
    HEATHEN
    from SIDNEY, NY
    461, 462, and 291 castings all had the double hump symbol cast on the end of the head. All of the 275 and 300hp engines got 1.94/1.50 valves; you had to get into the high performance 327s--350, 360, or 375 hp--to get the same castings with 2.02/1.60 valves. Feel free to research this further; when the talk turns to vintage sbcs, the ******** seems to flow heavily.
  15. lippy
    lippy
    from Ks
    The gentleman wasn't trying to be a smart *** or buy the engine. He was just saying his 327-275 didn't have 1.94 heads and was original. It got me to thinking maybe my memory was off.:D I also have a 67 300 hp 327 and it has 2-1/2 inch manifolds. Like I said I ran the suffix and it comes back a 65 327-275. Not trying to be anything I just never saw a 275 or 300 without double humpers. Lippy
  16. banjo
    banjo
    im the guy in question, already pm'd lippy, and bob, if i were closer/ had the garage space, I would have it.i was 18 when i had the car in 73, we/ i knew nothing of #s back then, and didnt care.
  17. CB_Chief
    CB_Chief
    from Oklahoma
    Around here those manifolds are worth as much or more than the heads. I have seen the regular 2" manifolds at swapmeets with $200 per set price tags. I wouldn't give that but apparently some will because they sold.
  18. Not all 327s had double hump heads, that is like saying that all big block chevys are 427s. Some had power pack heads or what we called power pack heads with the diamond on the front and power pack springs, some just had a square block on them etc.
    I found a site when this came up in a DZ302 thread a while back I'll see if I can find it again. It shows all the markings and the years that they were available on GM 327 heads.
    Here knock yourselves out.
    http://www.fastnuf.com/Headguide.html
  19. HEATHEN
    HEATHEN
    from SIDNEY, NY
    $200 for a pair of two inch ram's horns? I need to load all of mine up and head for OK!
  20. falcongeorge
    falcongeorge
    from BC
    My '66 275HP has 461 double humps on it. Every 2bbl 327 I have ever seen had the small heads on it.
