Technical SBC head/Valve train question
Discussion in 'The Hokey Ass Message Board' started by Dooley, Feb 13, 2020.
  1. Dooley
    Dooley
    from Buffalo NY
    I'm swapping over the 993 heads on my 355 to a set of 186.
    Right now I have stock type roller tip rockers with no guide plates.
    The 186 heads are machined for screw in studs so I'll need to use guide plates and the pushrod holes appear to be different from the slotted ones on my current heads.
    I know you need treated pushrod with guides but can you run the regular roller tip rockers or do I need to change them
    Deuces likes this.
  2. 2OLD2FAST
    2OLD2FAST
    from illinois
    No guide plates on those heads . roller tip rockers will work .
  3. Dooley
    Dooley
    from Buffalo NY
    My studs will bottom out without the guide plates could I use washers?
  4. saltflats
    saltflats
    from Missouri
    You need guide plates or you will have to run self aligning rockers.
    Looks like the push rod holes have been drilled out.
    Truckdoctor Andy and Deuces like this.
  5. lippy
    lippy
    from Ks
    I would say if you need to put washers under the studs, then guide plates will be what you need. I would run the guide plates, at high rpm that valvetrain will be all over the place. JMO. Lippy
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    You're right , those holes have been opened up ...
    Deuces likes this.
  7. Deuces
    Deuces
    Yep!!!!.... I'd be looking for leaks inside the intake ports also....
  8. DDDenny
    I ran the "186" heads on a 355, good heads(1970 castings).
    Deuces likes this.
  9. Dooley
    Dooley
    from Buffalo NY
    You thinking that they hacked into the intake runner's?
    I'll check later
    Deuces likes this.
  10. raven
    raven
    Another vote for guide plates. Cheap insurance.
    r
    Deuces likes this.
  11. Dooley
    Dooley
    from Buffalo NY
    Here are some pics.
    Deuces likes this.
  12. raven
    raven
    Yea, at higher rpms, your pushrods will be all over the place.
    r
  13. Dooley
    Dooley
    from Buffalo NY
    Yes I'll get guide plates
    I can still use my roller tip steel rockers?
  14. Dooley
    Dooley
    from Buffalo NY
    Do I need to change pushrods?
  15. Deuces
    Deuces
    I ummmm... Nevermind! :oops: Your in good shape.. ;):)
  16. Deuces
    Deuces
    Hardened steel pushrods and guide plates should do it!...
  17. Deuces
    Deuces
    Yes!....
  18. Dooley
    Dooley
    from Buffalo NY
    They don't look ok?
  19. Ericnova72
    Ericnova72
    from Michigan
    If you use a non hardened pushrod with a steel guideplate, the guideplates will eat the pushrods in a short amount of time, filing them away at the contact area.
    You need the guideplates due to the drilled out pushrod holes, you can re-use your roller tip rockers, you need new hardened pushrods for use with guideplates if what you currently have with your roller tipped set-up isn't already a hardened aftermarket pushrod. a file can quickly tell you if they are hard.
    Dooley likes this.
  20. Dooley
    Dooley
    from Buffalo NY
    I meant the heads
  21. 2OLD2FAST
    2OLD2FAST
    from illinois
    Go to "alexsparts" on the net he has great prices on adjustable guide plates + pushrods, etc ,save yourself a few bucks ...
    Dooley likes this.
  22. Budget36
    Budget36
    What style of rocker do you have?
  23. Dooley
    Dooley
    from Buffalo NY
    Steel stamped type with roller tip
  24. Dooley
    Dooley
    from Buffalo NY
    Summit brand
  25. Budget36
    Budget36
    Are they self aligning rockers or not?
  26. raven
    raven
    Roller tip are not self aligning
    r
  27. Dooley
    Dooley
    from Buffalo NY
    Then I need new rockers
  28. Hollywood-East
    Hollywood-East
    To answer your question, Your head's are Fine! No worries on intake
  29. Hollywood-East
    Hollywood-East
    An no, your roller tips are also fine..
    Guide plates an pushrods hardened... An Go
    lippy and Dooley like this.
  30. Ericnova72
    Ericnova72
    from Michigan
    No, you don't.
    You need guideplates, screw-in studs, and hardened pushrods....then just re-use your roller tipped rockers.
    Done.
    The guideplates take the place of the once slotted cast-in pushrod guide holes that have been drilled out, and thus keep the non self aligning rockers located correctly,... and the hardened pushrods solve the problem of the hard steel guide not being self lubricating like cast iron was with the old stock unhardened pushrods.
    Dooley and Truckdoctor Andy like this.
