SBC Hilborn EFI Conversion
Discussion in 'Parts For Sale' started by long door 40, Sep 9, 2014.
  1. City: Meridian
    State: Idaho
    Price: $2000
    Small Block Chevy Hilborn EFI conversion for sale.
    Manifold is real good no dings warps or damage.
    Custom made remote thermostat housing along with radiator hoses and 180 degree thermostat.
    Butterfly shaft bores are tight, new shafts and butterflies are included.
    Injectors are Venom HP-619-8, 19 lb per hour that will support up to 300 hp.
    New Velocity stacks along with air filters from Hilborn (minimal).
    Electronics: ECU is a Megasquirt, MS1extra lap top adjustable including all cables and harness's for hook up. Sensors included are coolant temp and inlet air temp, also Innovate LC-2 wide band O2 sensor with AFR gauge with green display.
    Machined oil fill cap at front of manifold.
    Various bracketry, throttle cable and support for thermostat housing.
    Manifold was installed on a relatively stock 283, far below the 300 hp range of the injectors. The ECU is programmed for this engine size and injectors, does run and drive but does need some more programming to get it right on the money. Your engine may require different settings, easily done with Tuner Studio from DIY Autotune.
    Asking $2000
    Contact
    Steve at slpratt@cableone.net
    or
    208-350-6376
