sbc identfication
Discussion in 'The Hokey Ass Message Board' started by Vete 67, Aug 19, 2010.
  1. Vete 67
    Vete 67
    Hello, I am new here so if I mess this post up please forgive me.
    I just bought a SBC 350 bored .030 over and releived for a stroker crank. I have looked a several sites trying to identify this block as what year it is and have not come up with a match to any numbers I have from the block.
    Casting numbers: GM 5.7 LG 14020038 The two 0's could be something else in that the casting is extremely poor and not ledgible at all.
    Engine Pad: V0120FBM Th1717403
    Any help with my problem will be greatly appreciated.
    Thanks
    Steve
  2. Go to www.mortec.com
    Look for chebby block casting numbers and then look for your number.
    OK now you got info from me its your turn, an introduction although no longer required is considered good etiquette. IE where you are comming from old rods, souped muscle cars etc. You should probably avoid the R__Rod term as most of us find it a little offensive.
  3. 52 csb
    52 csb
    Welcome Vette 67, those #s do not jive with ones i have listed.....1402 ?? Good Luck 52 csb:)
  4. Vete 67
    Vete 67
  5. Russco
    Russco
    from Central IL
    With 5.7 casting on it its a post 1985 350 nothing special about it,more than likely out of a truck
  6. chaddilac
    chaddilac
    Yea I got nothing with that casting number.... is that the number on the top of the bellhousing behind the head? should be on the driver side. The pad numbers are not always correct and are unrealiable!!!
    Take a pic of the casting numbers if you can and we'll help you out!!
  7. V0120 (V=Flint Michigan, 0120= Jan 20th)
