Hot Rods SBC IDhelp please.
Discussion in 'The Hokey Ass Message Board' started by Gotty, Jul 17, 2021.
  1. Gotty
    Gotty
    I am probably being thick, but I can't work out my engine details for spec etc.
    I have a SBC with casting at rear of 3970010 a bit further along is a K and further along a 2.
    The details on the decking plate are.
    T6B507553 & K11 19 TYX.
    There is also at the rear the numbers 010 & 979.
    Any help would be greatly appreciated.
    Gotty
    Deuces and 42merc like this.
  2. TYX 1975 350 conv.cab L LS9 165 4 C-10 to 2500
    loudbang and Deuces like this.
  3. In other words a smogger 350 with a 4bbl carb Probably a 4 bolt main being from a truck..
    loudbang, Deuces and squirrel like this.
  4. squirrel
    partial VIN
    T=GMC truck
    6 = 1976
    B = Lansing
    Deuces likes this.
  5. 1934coupe
    1934coupe
    Most of the GMC motors I have seen had forged steel cranks. I would think that if the "core shift" isn't bad it may be a good block to build, nothing wrong with a "smogger" regular gas and cool running. Conservative cam and carburation and you are good to go. In my opinion.
    Pat
  6. Gotty
    Gotty
    Thank you
  7. Gotty
    Gotty
    Thank you.
    Deuces likes this.
  8. Gotty
    Gotty
    Thank you
    mgtstumpy and Deuces like this.
  9. Mario p herrera
    Mario p herrera
    010 in the back means high nickel Wich means it's a good strong block
    Deuces likes this.
  10. squirrel
    010 the back means it's a 350 from 1969-1979. It has no other significance.
  11. Budget36
    Budget36
    Jim’s right. High Nickel is a wives tale.
  12. warhorseracing
    warhorseracing
    from cameron wv
    If there are any traces of orange paint it is from a vette!;)
  13. 51504bat
    51504bat
    If so, no need to pull the pan its a 4 bolt main.:cool:
  14. squirrel
    if there are any traces of orange paint, don't be surprised. Most of them were painted orange. the last couple years were blue. And when they get rebuilt, who knows...
    Most of them were also 4 bolt mains, especially those used in trucks.
    It's just another of millions of smog truck 350s.
  15. Deuces
    Deuces
    I got lucky a couple of times getting a 350 4-bbl motor out of a '70-'71 GMC pick up.... The block had 4-bolt mains and a steel crank including the beefier truck "X" connecting rods....
  16. Mr48chev
    I've found that a lot of the truck suffixes and other codes don't show up on several ID your Chevy engine pages. I've spent a half hour searching before only to find that Jim and maybe another had posted the info while I was hunting and getting skunked.
  17. squirrel
    I use books a lot of the time. I have the Chevy parts book for trucks from 1969, and 1972, and also used to have a truck flat rate book from the 70s that had a lot of them.
    partssaloon and Deuces like this.
  18. 1971BB427
    1971BB427
    from Oregon
    Trucks can have 2 bolt main blocks too. I've come across a number of 1/2 ton trucks with 2 bolt main SBC engines. GMC or Chevy.
    Desoto291Hemi likes this.
  19. squirrel
    from what I've seen in the 70s there were some 2bbl truck engines that were 2 bolts. The 4bbls seem to be mostly 4 bolt.
    But there are some exceptions, of course
    Desoto291Hemi and Deuces like this.
  20. Gotty
    Gotty
    That's a lot of info and help. Thank you all. I ***ume the only way to see if 2 or 4 bolt mains is to take the sump off?.
  21. squirrel
  22. The man ( squirrel ),,is right,,,,,as usual .
    My dad gave me an old 350 short block several years ago,,,,,an 010 block .
    I was really excited,,,,expected a 4 bolt main,,,,,,pulled the pan later .
    Nope,,,,,,,2 bolt ,,,I was really shocked,,,,,all the 010 s I had ever seen were all 4 bolt main .
    That taught me I didn’t quite know all I thought I knew,,,,LoL.
    Tommy
    Lloyd's paint & glass and Deuces like this.
  23. Or take the oil drain plug out and stick one of the little borescope cameras in to take a look.
    Hnstray, Desoto291Hemi and Deuces like this.
  24. Gotty
    Gotty
    Now that's worth a try :)
    Hnstray and Deuces like this.
  25. I’m sure there is a couple hundred jokes that could come from that…..
    Deuces likes this.
  26. Deuces
    Deuces
    Those do work if you're careful with them... We use one at work to check for stelag***es (sp) in aluminum castings....
  27. Gotty
    Gotty
    Needed to take the sump off and its a 4 bolt main block. Bonus :)
    swade41, KiWinUS and squirrel like this.
