sbc idle question
Discussion in 'The Hokey Ass Message Board' started by hotrod 32 ford, Sep 17, 2012.
  1. Sbc 350 edelbrock carb and intake.. Wont start unless on full choke . Touch throttle and it dies instantly. Any ideas ????
  2. Nope. Just tried a can of carb cleaner all over engine. No difference in idle.
  3. If it runs full choke only its one of two things.
    Too much air like a vacuum leak. Chevys can leak under the manifold
    Or not enough fuel.
    Edelbrocks want two things from you - 4.5 psi fuel pressure and to be clean.
  4. Yeah, it's an Edelbroke! ;)
  5. DAVEO!
    DAVEO!
    Bad vacuum leak or out of time
  6. DAVEO!
    DAVEO!
    or try another carb
  7. Forgot to add im running a manual fuel pump with an inline filter
  8. WTF is a manual fuel pump , like they had on green acres ?
    What's the fuel pressure at the carb inlet ?
  9. One with a hand crank! :D
  10. Ha Ha!
    That's it Moose!
  11. Oh boy !
    That'd be the problem,
    That's a two handed manual pump and you can't work it if one hand is holding the choke closed.
  12. Hummm...
    You think that's where they got the saying "crank it" from?
  13. c-10 simplex
    c-10 simplex
    Does this carb have any choke pulloffs?
  14. enjenjo
    enjenjo
    from swanton oh
    You have the PCV port on the back of the carb plugged?
  15. Hapster
    Hapster
    accelerator pump?
