Technical Sbc in 1950 ford shoebox tech question.
Discussion in 'The Hokey Ass Message Board' started by 63shane, Jun 10, 2016.
  1. 63shane
    63shane
    OK so I'm installing a sbc in my 1950 ford shoebox. I'm using a 1999 chevy block so don't think i can run the nova oil pan as the dipstick is on the wrong side. And i don't want to modify my steering as its new and upgraded. Question is has anyone installed the sbc with stock oil pan and just raised the motor high enough to clear the steering and just rework the floor? Any info on if you have done this and how it worked out would be great. Oh and the stock Pan is about 2 inchs deeper than the nova so I'm thinking raise engine 2" max? Thanks!
    Sent from my SM-G900P using H.A.M.B. mobile app
  2. By Nova style pan from Moroso some other company that sells them. They sell pans to put an other then early block in a Nova. Or you could dry sump it.
  3. i put a later style sbc in a `49 Ford , but the car had Fatman mustang II .... so no real help there. what i can say that may be helpful is i was able to use the stock transmission crossmember by notching it a bit and welding on a new plate on the bottom
  4. 63shane
    63shane
    Hummm.. ok thanks I'll look into that. .
  5. amadeus
    amadeus
    Your issue I believe is that you are running a 1 piece rear main seal?
    Try this from Cl***ic Industries
    Product #: N130191
    Not sure if you will need to clearance the front cross member because of the design.
    We are currently installing a sbc on two of our car club members shoe box's but are using the 2 piece rear seal blocks with the OE style Nova pans. Looks like the engines sit rather high on these conversions, someone else might have better information and chime in.
  6. 63shane
    63shane
    Yes I'm using one piece rear main block the nova pan the dipstick is on the drivers side. . Mine is on pasanger side not sure if they're is away around that.
  7. Call Summit racing and ask them about your pan. It is not that big a deal. Tell them what you want give them your credit card number and wait 3-5 days.
    ffr1222k likes this.
  8. 63shane
    63shane
    So i guess no one suggest raising the engine up the 1 1/2 to 2 inchs to clear ?
  9. dan c
    dan c
    it's a moot point, but i think a lot of those swaps used to be done with a dropped tie rod, which were widely available. as i recall, the only serious mod you do to the front crossmember is cut a hole for the mechanical fuel pump--which you aren't using!
  10. I have done things like that which is why I gave you the advice that I did.
    ffr1222k and 283john like this.
  11. amadeus
    amadeus
    Shane, all you have to do is plug up the side of the block where the original dipstick is. The crate motors from GM give you some "blanking" lugs that go into the orifice where the dipstick presses into the block depending on what style of pan is required for the application. You can easily whip out a couple of lugs outta of aluminum or just silicone the hole, no big deal.
    1962-1979
    OIL DIP STICK DELETE PLUG
    FOR ENGINE BLOCK 3/8"
    As far as modifying the drag link to drop it and use a conventional pan , yes it can be done (that's how it was done back then) but the original design of the draglink in these cars suffers from bump steer and premature wear of the idler arm bushings (every couple of 1000' miles need to be replaced).
    The fellas in my club that are doing the engine swap got a really nice replacement draglink and idler arm set up from shoebox central which eliminates the inherent bump steer from the original design, it also uses a modern idler arm and is of much heavy construction vs. the original.
    Oops! Just realized that you did mention that you have upgraded your steering draglink!
  12. amadeus
    amadeus
    Also, you may already know this; (And at least on the two piece rear main motors)But the oil pan requires a special oil pump, oil pump shaft, and pick up; As well as a SPECIAL BOLT for the main cap to hold the oil pick up tube.
  13. bobss396
    bobss396
    Used the front-sump Nova pan on my '59 Ford swap, I had to shorten up the dip stick and tube, but have good access to it.
    TA DAD likes this.
  14. manyolcars
    manyolcars
    When the modern idler arm wears out, what do you ask for to replace it? Thanks
  15. bobss396
    bobss396
    And I did have to add a hole to hold the pick up tube... fun on an ***embled short block.
  16. manyolcars
    manyolcars
    Did they do all this in the 1960s? The first SBC/Ford I remember seeing was in a 1950 Crestliner in 1962
  17. bobss396
    bobss396
    The aftermarket early Nova rear sump pans that have the notch, they are meant to clear the centerlink only. Getting a tie rod to p*** through it is a **** shoot.
  18. bobss396
    bobss396
    I did a early Nova conversion using a '66 Impala 283, I don't recall needing to drill an extra hole for the tube.
  19. amadeus
    amadeus
    @ Manyolcars
    Unless you have the aftermarket replacement draglink; it isn't a "bolt on replacement" for the original idler arm. I will get you the part # for the modern idler arm once I get home from work. The replacement draglink is a completely redesigned and fabricated piece.
  20. amadeus
    amadeus
    @ bobss396
    I like the way you think Sir ! Simple and to the point! (I believe that's how the Chevy 2 Specific Engine Blocks attach the Oil pick up tube )
    Or
    This bolt is available from Chevy 2 Only Inc.
  21. manyolcars
    manyolcars
    I looked at shoebox central and definitely want your part number Thank you!
  22. 63shane
    63shane
    Thanks for all the info guys looks like the nova oil pan is a option. I just figured motor is already together. Nova oil pan and related parts cost me some money. Probably got s**** metal laying around to fab up some spacers to go under the mount brackets. Guess i was hopeing some one would say they have done that and it worked great. . Oh well may have to look more into pan options.
  23. manyolcars
    manyolcars
    I have cut and welded a pan to move the sump. Cut and welded the pickup tube too. It was free to do that. :)
  24. 63shane
    63shane
    Been doing some searches on pans . Found some that are real wide at rear and hold 7 qts why couldn't you shortin pan 2 inchs along with pick up tube and widen pan so you dont loose oil capacity? Hummm. Still seems easier to me to just lift engine to clear ...
  25. amadeus
    amadeus
    Just to give you an idea..
    These are the shoebox central (?)mounts with nova pan. About 2" higher (?)on cross member.
    I think a member from Australia did use a conventional pan and notched it at the rear to clear the steering linkage.
  26. 63shane
    63shane
    That last picture with the notched oil pan . To me looks like he could have just moved the tierods to the back side and it would of cleared. That looks like the shoebox central steering that's what i got and you can go in from anyway.. i did not mention i already have mount and ****** mount buy they're from jamco. .
  27. Xman
    Xman
    For what it's worth, I have done several of these swaps. The last one was a cherry 50 2dr sedan. I cut the floor trans tunnel and bellhousing area out. Then installed the engine and trans (ZZ4 and 5 speed) up high enough to clear the tie rod and cross member. Then went to the local wrecking yard and found a floor section that looked close to working. After some hammer work and heat, I had a new floor welded in. To me, the engine then looks proper, raised up instead of appearing to drag on the ground. Also, drive line alignment was correct.
    This was more work but the result is really worth it.
  28. Tim
    Tim
    from KCMO
    About 15 years ago I out a 283 in a 50 and had it up high like you describe.
    I had to cut out the bellhousing area, trans hump and the entire center of the floor to clear. I bit off way more than I had thought. The modifications needed to put it where it's supposed to go would have saved time, money and the car wouldn't have had the center of gravity so high.
    Get a different oil pan and mess with the steering or nearly cut your car in half. Your call
  29. Xman
    Xman
    Center of gravity to high, What?
    If modifying the floor so that the engine can be installed in the proper location is to much work or to complicated, I think Dirty Harry said it right.
    "Mans got to know his limitations"
  30. 63shane
    63shane
    That sounds like what i will do. . First I'll remove the center link and set motor and ****** in then try installing center link. . Start raising motor till it clears and see how it fits. I have noticed some looks like motor is sitting low so there should be plenty of room under hood.. thanks.
