Hot Rods SBC in 37 Ford
Discussion in 'The Hokey Ass Message Board' started by bubbajla, Jun 13, 2012.
  1. bubbajla
    bubbajla
    from Rogers, AR
    Can someone tell me if its possible to put a SBC in a 37 ford without having to cut the firewall? I have heard a short water pump and small distributor might be enough to avoid cutting the firewall...appreciate all comments!
  2. Finn Jensen
    Finn Jensen
    Mine fits fine without any change to the firewall. MSD distributor has plenty of clearance.
  3. Weedburner 40
    Weedburner 40
    Yes, with a short pump. No firewall mods needed.
  4. clubcoupe37
    clubcoupe37
    mine fit like a glove with a short pump like weedburner40 said...although it was a ***** to work out the radiator and fan...I will eventually change my firewall out for more room.
  5. hotroddon
    hotroddon
    Mine fits fine (37 Coupe, 327). Small body PerTronix Distributor. Plenty of room for radiator and fan (mine has electric but mechanical would fit.) Patriot long tube headers as well.
  6. bubbajla
    bubbajla
    from Rogers, AR
    thanks for the helpful information! Much rather change distributor / water pump than move everything...
  7. Texaswino
    Texaswino
    Mine has a LT1 and stock firewall and radiator
  8. spiders web
    spiders web
    Why don,t you either put a ford mill in it or go find a chevy body and ch***is. I guess you only have a limited budget so go ahead and get that walmart motor..
  9. jcmarz
    jcmarz
    from Chino, Ca
    Typical delusional Ford lover.
    Chevrolet U.S.A-1
    05snopro440 likes this.
