1952-59 Ford SBC IN A 56 FORD?
Discussion in 'Off Topic Hot Rods & Customs' started by mikhett, Feb 21, 2016.
  1. mikhett
    mikhett
    from jackson nj
    I KNOW this may be blasphemy but has anybody ever put a SBC in a 56 Ford?I HAVE A 350 THAT NEEDS REBUILDING and it would be cheaper than building my 292.thanks.
  2. 56longroof
    56longroof
    Anything is possible but, why would you want to? You can get a 302 on the cheap and have about as much in it as a small block scrubby.
    chopd top and JeffB2 like this.
  3. Mark T
    Mark T
  4. okiedokie
    okiedokie
    from Ok
    I am sure it has been done many times but this is not the place to look for info. I have a Chevy in my 40 because I did not want to cut the firewall but if a Ford motor fits as easily ,which it does, [in fact fitting a Chevy would require a front sump pan I think] then why not? Sell the Chevy and buy a 302, make life easier.
    Texas57 likes this.
  5. mikhett
    mikhett
    from jackson nj
    OK I asked.You answered.Ill have to price out a 292 rebuild an find a machine shop familiar with the y block.Gotta remember ys are 60 years old!
  6. 56longroof
    56longroof
    My recommendation would be to contact Tim McMaster. He built my engine and he usually has rebuilt engines on hand. Not sure of your budget but I paid $3000 for mine. That includes head porting,bigger valves,engine break in,and other performance mods. If you have a specific item such as dizzy or carb and intake he installs and tunes engine with your items. He installed my MSD dizzy and made up the plug wires for no additional charge.
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    Chevy is a bad fit in your Ford,rear mounted oil filter creates a challenge with the steering box making fabricating an exhaust :eek: also the oil pan issue as mentioned.
  9. Mark T
    Mark T
    Ford FE would be a better choice, and easy to install.
  10. kgdb
    kgdb
    from The 60"s
    Its been done many times, why I dont know but it has been done. Please don't go that route or if you do don't open your hood at any events. lol. If you don't want to rebuild then go sbf, they are a dime a dozen and you could swap it very easily.
  11. bobss396
    bobss396
    I just did one in my '59 since I already had it. And I wasn't keen on dropping a boat anchor (FE) in it. Doable for sure, I used an early Nova pan. We made up the ch***is mounts, but look up Butch's Cool Stuff. He has a mount package for the swap.
    And from now on, you guys will be getting full-size pictures. No more of that thumbnail nonsense.
  12. HOTRODPRIMER
    HOTRODPRIMER
    I've stuffed a lot of sbc's in '30 through '40's Fords mainly because the dimensions of the sbc are close to those of the Flathead V8.
    I wouldn't consider a sbc under the hood of a 52-59 Ford,302's are inexpensive and fit like a glove. HRP
  13. Edsel58a
    Edsel58a
    I agree on many points. Drop a small block Ford in it. No muss, no fuss. A tougher to find 351C would be better because the exhaust fit is better.
    Sell the sbc to fund the project.
  14. bobss396
    bobss396
    0222160718.jpg Dollars dictated the SBC.. and I get to "tick" off a lot of people, got you guys going...
    JeffB2 likes this.
  15. JeffB2
    JeffB2
    from Phoenix,AZ
  16. Edsel58a
    Edsel58a
    Dollars or time...... Hmmmm.... I'll spend the few bucks, save the time.
  17. bobss396
    bobss396
  18. Edsel58a
    Edsel58a
    Back at ya
    Bad Henry and Rui like this.
  19. Jimmy2car
    Jimmy2car
    from No. Cal
    Find another forum
  20. bobss396
    bobss396
    I'm having fun and I do own a Ford.... or put me on ignore. That's what I do on the main HAMB board, here I like everyone.
  21. bobss396
    bobss396
  22. Edsel58a
    Edsel58a
  23. Mark T
    Mark T
  24. Edsel58a
    Edsel58a
    Sorry Jimmy... I have a 54 Ford and a 58 Edsel, both all Ford. Wouldn't consider a different engine or anything else for that matter.
  25. JeffB2
    JeffB2
    from Phoenix,AZ
    I gave a gave a guy on hotrodders.com a bunch of advice on a swap, he has a 302 Ford in a '51 Chevy coupe it actually is a better fit than an SBC in the same car.
  26. Edsel58a
    Edsel58a
    I know a guy with a 351 in a 48 Chevy and he said the same thing Jeff
  27. Edsel58a
    Edsel58a
    Nice one Mark....... I think we hijacked Mikhett's post.
  28. JeffB2
    JeffB2
    from Phoenix,AZ
    No way :D Just an exchange of ideas, right?
  29. bobss396
    bobss396
    I was surprised at how well the Chevy went into my Ford. Once I had the Chevy II pan on it, I started with the mounts. Clearance at the firewall is tight, went with a small-body distributor. The starter comes out easy, fuel line is on the correct side. I doubt a 351 or 460 would have gone as well.
  30. bobss396
    bobss396
    This is what its all about. You learn a lot about people when they slam another guy's build. But it helps me distinguish the real car guys from the posers.
    rustyfords likes this.
