Technical Sbc intake?
Discussion in 'The Hokey Ass Message Board' started by JimSibley, Jun 16, 2019.
  1. JimSibley
    JimSibley
    i have a 327 that i am building for a g***er style a coupe. I am running a 3500 stall, turbo 350 with a 9 inch ford rear with 3.55 gears. The motor is .30 over and has a steel crank and a healthy cam in it. I bought the motor with ***ault 2.02x1.60 aluminum heads. They have really tall intake runners and i am having a hard time finding an intake to cover them. I want a dual plane, drivable intak with a single carb, any suggestions?
    Deuces likes this.
  2. desotot
    desotot
    Do you have a pic?
  3. wraymen
    wraymen
    I would contact ***ault Racing Products. I don't think those heads are available any more but they should know what will match up. They sell intake manifolds. JMHO but everything on the site looks like a knockoff. Might want to research the heads a little more.
    lothiandon1940 likes this.
  4. JimSibley
    JimSibley
    I asked around about the heads, they work good, but they ate definitely chinese knockoff junk. I will call them about an intake, just wondering if anyone on hear knows of a tall runner intake that should work.
    Deuces and wraymen like this.
  5. slayer
    slayer
    A friend of mine ran into the the same issue on his small block ford with afr heads and a vintage tunnel ram. He had the tunnel ram welded up over the ports and then port matched the runners.
    Deuces and lumpy 63 like this.
  6. wraymen
    wraymen
    Since it has a healthy cam you might want to upgrade the springs. It seems that is where some failures come from with the Chinese stuff. It's kind of ironic because most of the heads are ***embled here. Maybe the springs are from there also, I have no idea.
    lothiandon1940 and Speed Gems like this.
  7. JimSibley
    JimSibley
    Thanks wrayman, i will have them checked out
  8. Deuces
    Deuces
    How's about a Edelbrock R.P.M. intake???
    OLSKOOL57 and Just Gary like this.
  9. mohead1
    mohead1
    Cant believe the runners are that high....even the chink stuff will match a stock intake pattern.....hmmmm...something aint rite
    Sent from my SM-G900V using Tapatalk
    Deuces likes this.
  10. mohead1
    mohead1
    Them heads havint been milled all to hell have they? Like angle milled that requires the intake to be milled to match??
    Deuces and '49 Ford Coupe like this.
  11. Mike VV
    Mike VV
    from SoCal
    Jim -
    No Chevy engine in existence will bore .30" over AND....still be usable..!
    Mike
    Johnny Gee and norms30a like this.
  12. mohead1
    mohead1
    Lmao.....thaats rite
    Deuces likes this.
  13. Ericnova72
    Ericnova72
    from Michigan
    Those heads are a import copy of the Dart Pro-1 Platinum 200cc head. They have an approximately .100" taller intake port, just like the Darts also have. The casting is a well done copy, not junk.
    You'll find the same issue with a lot of modern performance heads.
    Most moderate dual plane(Performer, Performer EPS, Street Dominator, Action Plus, Cyclone)and low-rise single planes(Torker, Torker II, Accelerator, Holley Z, StreetMaster) will be too short to cover the top of the port opening.
    You'll need a taller high performance dual plane(Performer RPM , Stealth, Speed Warrior, Typhoon, RPM Air Gap, Crosswind), or a high-rise type single plane(Victor Jr, Super Victor, Victor E, Victor 4x4, Team G, Hurricane, Strip Dominator) to be tall enough at the port opening to cover.
    You won't find any vintage dual plane or single plane intakes tall enough except for some of the race tunnel rams(Victor Ram, ProRam II, Team G Ram, Strip Dominator Ram).
    Most of the street Tunnel Rams, 60's and 70's "race" tunnel rams, and the Cross Rams won't cover the port either.
    pitman, Deuces, loudbang and 2 others like this.
  14. Snegrah
    Snegrah
    from Pacifica
    Really?
    Sent from my SM-G965U using The H.A.M.B. mobile app
    Deuces likes this.
  15. JimSibley
    JimSibley
    I meant 030 over, sorry, my mistake.
    Deuces likes this.
  16. JimSibley
    JimSibley
    I have a victor jr. When i can get up for more than a minute( just had open heart surgery) i will put it on there and see if it covers, thanks for all of the info.
  17. Slopok
    Slopok
    Aren't you supposed to be takin' it easy??? :confused:
    You're not gonna heal as quickly as you can build your cars!
    JimSibley, Deuces and mohead1 like this.
  18. belair
    belair
    Settle down, fella, that **** will be waitin for you tomorrow.
    lothiandon1940 and Deuces like this.
  19. thecj3man
    thecj3man
    from TN
    I used a dual plane Brodix HV-1016 for the 350 in my 55 Chevy. It had a lot more material around the runners than the Edelbrock I considered using.
    JimSibley and Deuces like this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Looks like a whole number that will roll after 999. :D
