so i have a 86 chev 350.... out of a blazer. its fuel injected, and has the center bolt valvecovers. i want to put it in a 68 impala, with a powerglide..... will everything interchange? will the flexplate be the same? are there aftermarket intakes for carbuarators? anyone know???? thanks in advance, rich
Probably will need to change out the flywheel. changed to external balance around then. Them diameter at the end of the crank changed so it's easy tro tell by trying to firt one or the other onto the end of the crank. jerry
