Hot Rods SBC low alternator mount?
Discussion in 'The Hokey Ass Message Board' started by Kona Cruisers, Dec 13, 2024.
  1. Kona Cruisers
    Kona Cruisers
    is there a low mount out there the looks... remotely not modern?
    everything looks 1800hotrodparts.com or billet.
    hoping knows of one not absolutely hideous.
    thanks
    levi
  2. skooch
    skooch
    alanp561, dana barlow, hrm2k and 3 others like this.
  3. blue 49
    blue 49
    from Iowa
    ^^^ It would look better with hex-head bolts. I wouldn't trust those Chineseum socket-heads, anyway.
    Gary
  4. DDDenny
  5. okiedokie
    okiedokie
    from Ok
  6. TCTND
    TCTND
    Pretty simple to make whatever you like; that's hot rodding.
  7. pprather
    pprather
  8. bschwoeble
    bschwoeble
    Street Rodder magazine in the early 70s, had instructions on how to make your own, like the one on Ebay. Back when people built their own parts/cars.
    rpm56, ramblin dan, 2OLD2FAST and 2 others like this.
  9. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    I've used several of the 209L brackets from Alan Grove that use the smaller CS130 GM alternator and tuck it in tight on the left side but not hanging to low. Like all the AG brackets well built and designed.
    lurker mick, 325w, swade41 and 6 others like this.
  10. Weedburner
    Weedburner
    from Wa State
    Here's some pics of one I made from 3/4"x1" steel bar stock and 3/4" dia cold rolled round. Rectangular stock was bent in my press...
    This one has been to 8600 many times, never thrown a belt.
    Grant
    alanp561, Driver50x, vtx1800 and 5 others like this.
  11. X-cpe
    X-cpe
    Here's what I built for mine. It slides the alternator up and down the side of the block.
    Relaxed position
    Max tension position.
    Two piece mount bolted together and to the block.
    The two pieces of the mount.
  12. gimpyshotrods
    gimpyshotrods
    51504bat likes this.
  13. TA DAD
    TA DAD
    from NC
    I was able to hang mine down low using a homemade bracket on the head. IMG_0374.JPG
    Driver50x and X-cpe like this.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ That’s not strong enough. :)
    bschwoeble, patsurf and anothercarguy like this.
  15. D-Russ
    D-Russ
    Homemade from three pieces of 1/4 inch flat stock stacked together. A piece of heavy wall tubing spaces the alternator to align with the pulleys. Short water pump and Nippondenso alternator.
  16. skooch
    skooch
    Grove bracket on eBay,I just posted 2 examples of available brackets. One expensive one cheap.
  17. RodStRace
    RodStRace
    I started a bit of a storm asking about this. I will mention that it depends on if you are going short WP which doesn't allow for a std GM alt to be tucked in or a long WP which does. You didn't say which side, either.
    Of course, one of the modern mini alts. increases the choices.
    I have decided on the Alan Grove p***enger side mount, but haven't pulled the trigger yet.These fine people with raw stock, cutting and grinding equipment and welders ready to go are correct. It can be done at home for not much money. If you are working in less fortunate cir***stances, but have a few bucks, there are choices that don't look like 1-800 bling.
    https://ncspeedlab.com/products/alt-bracket-mid-mount-sbc-long-water-pump
    I'll also note that in my case, the WP is a basic one that doesn't have the required extra mounting holes. This means I've got to get another WP too.
  18. scofflaw
    scofflaw
    from Ohio
    Kind of hard to see but I used the referenced eBay kit with a short water pump and standard GM 10SI alternator. It’s tight but works fine.
    deuceman32 likes this.
  19. krylon32
    krylon32
    Alliance Vendor
    from Nebraska
    Also the Grove 209L doesn't hang the alternator below the plane of the crank pulley.
  20. Fordors
    Fordors
    I’ve shown this before, I my case I had a Vega box in the way. I used a Saws All and removed the fuel pump boss, ground the ugly stuff smooth and plugged the holes with core plugs. One bracket that bolts to the p***enger side motor mount holes in the front of the block and a short piece of 5/16 ID heavy wall tube to serve as the belt adjuster is all it takes. Short pump with a factory two groove pulley lines up perfectly and I put a belt on from the crank to water pump just I case I lost the alternator belt. It may not look like it but the radiator hose clears just fine. IMG_2623.jpeg
    Maybe a little extreme but I didn’t want a high mounted alternator
  21. TA DAD
    TA DAD
    from NC
    That's what I was thinking !
  22. ramblin dan
    ramblin dan
  23. ramblin dan
    ramblin dan
    How many guys remember mounting the alternator under the car running off the driveshaft? a few guys with T-buckets I know ran this setup back in the day.
  24. 1biggun
    1biggun
    Dick Stevens, mad mikey and X-cpe like this.
  25. 1biggun
    1biggun
    In considering it on my 31 A PU build with no fenders and a 32 shell was also thinking of a AC compressor under there as well . Im going to run a magneto ignition so in traffic id be Ok and well for the AC Id need to be moving but it would be better than no AC .
    Figure I could hide the lines mostly and put the rest under he seat .
    Planned on a big battery in the back to put some weight there anyway .
    Im hoping this will use my 331 Hemi if I can ever get going on getting it running .
    Alternators charge spinning in either direction so one could also turn them around to fit them in a better location
    there are ready made set ups to put the alternator on a 9" rear end
  26. Phil P
    Phil P
    Phil
    39custom, skooch and mad mikey like this.
  27. brigrat
    brigrat
    from Wa.St.
    Driver50x, X-cpe and mad mikey like this.
  28. 19Eddy30
    19Eddy30
    from VA
    Here is my BS design , started with cardboard, Inside rails of A - 34,
    P*** Side mouthing, under water pump inlet , No fuel pump , Keep low
    & short water pump , infront of engine mount , beside oil pan, 100 amp Denso,
    Other a Zip set up , based on short pump
    Driver50x and skooch like this.
  29. X-cpe
    X-cpe
    Thanks for the compliment!
    Not a chance of making them for sale. It is a one time deal to solve a fitment problem in a home built ch***is. I just posted it as one possible solution. Besides, do you know how long it takes to make curved slots with a drill, cold chisel and a half round file?
    alanp561, Driver50x, patsurf and 2 others like this.
  30. 19Eddy30
    19Eddy30
    from VA
    Yes !!!
    Like dial up on a Rotary phone:eek:
