Technical SBC low profile distributor help needed!
Discussion in 'The Hokey Ass Message Board' started by Gearhead Graphics, Sep 2, 2020.
  1. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
    Like a dummy I got into a tight spot with the distributor on my t bucket. I sunk the coil into the firewall, and now with the motor on there isnt room for the both.
    I need a lower profile cap. 5 inches would be ideal. Prefer something that doesnt have to have an external ignition box, again, T bucket, tight on space.
    It seems the majority of crab claws and low pro setups im seeing are needing of an external box. Can anyone save me and direct me to a low unit that is drop and go?
  2. Mr48chev
    I don't have the crab cap but I picked up a Mallory 520CV marine distributor that can use one for my flathead. The advance works with the flatheads but doesn't do well on a Chevy street motor.
    The description on this one on Ebay makes it sound like junk but I am just posting the link so you have a visual image of how tall the unit is.
    333197774291
    Seller ***umes all responsibility for this listing.
    Link to Summit's listing on the cap. https://www.summitracing.com/parts/maa-221b You can find them for less than that though.
  3. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
  4. Ericnova72
    Ericnova72
    from Michigan
    I don't believe you are ever going to find a low cap distributor that doesn't require an external box....reason being in order to make them that low they have to remove something to get the space, so either the points or module and the mechanical advance parts are what is eliminated and the distributor then just becomes a spark director.
    If there is a solution, it is likely to be something vintage....there won't be anythng currently in the new market.
    You could go external box, and hide the box under the dash inside the car. but as far as i know, all the current low cap distributors require a crank trigger to feed signal to an external box.
    swade41 likes this.
  5. panhead_pete
    panhead_pete
  6. Ericnova72
    Ericnova72
    from Michigan
    That distributor is computer controlled, it has no mechanical advance mechanism in it. It is just a magnetic pick-up and rotor, no module to convert the mag pulse into coil trigger signal. It can't be used stand-alone with just a coil.
  7. brigrat
    brigrat
    from Wa.St.
    Just being facetious!
  8. pprather
    pprather
  9. pprather
    pprather
  10. Time for a ford mill
  11. Ericnova72
    Ericnova72
    from Michigan
    This cap goes with their Flat top Pro-Billet SBC distributor, along with also fitting a crank trigger distributor and a Ford Flathead distributor. It doesn't fit any other distributors, like a regular HEI
    The Flat Top Pro Billet distributor has a mechanical advance, but no vacuum advance, and is 4.875" tall according to one review....but it also requires a ignition control box, it isn't a self contained distributor.
    https://www.speedwaymotors.com/MSD-84891-Chevy-Flat-Top-Pro-Billet-Distributor,104220.html
  12. goldmountain
    goldmountain
    Probably easier to rework the firewall.
