I'm a kid building a 52' Mercury Flathead in shop. I wanted to run a mag. I herd that you can run a SBC magneto with a little machine work, is this possible? and if it is how? If it is I will probably borrow a flathead mag or distributor to copy the shaft measurements to do the machine work? Thanks, Max
I can't see why not, Chevy distributors are cut down to fit in flatheads. I used a chysler distributor. I liked to hear more about this .
This question has had me thinking about a mag also. But there are a couple of "quirks" in the flat head ignition system that I haven't heard how you allow for them. (or that work properly) Especially if the engine is BLOWN. 1. Ford used a vacuum break - the vacuum lifted the break plunger; - (up to 1948) 2. Then diaphragm, which is the opposite to conventional vacuum advance ignitions - but NO centrifugal advance. The question that arose was "Where do you connect Vacuum ADVANCE" when installing a magneto ignition with a blower (S.C.o T.) ??
Mags normaly were mechanical advance only. So no worries about a vacuum advance. Remember mags were usually a performance item so the vacuum advance was not wanted/needed. To use a say Chevy mag in a flatty it would need to be re-curved for sure as a flathead does not like as much advance as a SBC.
Here is what we did to convert a Chevy - I don't think this is what you meant - in our case, it also had to be reversed...
