Technical SBC mini starter nose support bracket
Discussion in 'The Hokey Ass Message Board' started by hotrodA, Feb 28, 2025.
  1. hotrodA
    hotrodA
    Howdy!
    Is there a OE starter nose support bracket for this late model SBC mini-starter? Or just make/modify an early one? Or don’t need one?
    Thanks!
  2. Dooley
    Dooley
    from Buffalo NY
    I have a mini starter with no support
    SS327 likes this.
  3. Curious about a support too. I put one (mini starter) in my 327 a few months back and worked great, no shim. Maybe a couple months later it started to make a shring sound and then a terrible noise. I've been doing some cleaning, polishing and painting while it's out and I'm going to put a shim in when it goes back in. I'm wondering with no support if it moved.
  4. TRAVLR
    TRAVLR
    The front starter bracket was only used on the original style early starters on small and big block chevy's because of the starters were so heavy. Never seen or needed the bracket for the lighter mini starter.
  5. hotrodA
    hotrodA
    Thanks for the responses.
    I was curious not for the weight, but to resist any torque trying to crack the aluminum mount to the block.
    If the GM engineers didn’t think it necessary, then probably not needed. Just do’t let it get loose.
  6. swade41
    swade41
    from Buffalo,NY
    I don't run one on mine and have no issues
  7. TA DAD
    TA DAD
    from NC
    The main thing is the proper bolts with good knurling to keep the starter from moving.
    olscrounger, Slow down, X-cpe and 2 others like this.
  8. Yes, I used the bolts that came with the starter motor, a Jegs unit, and retorqued after the first hint of shring which solved for a short time. When it worsened the bolts took no torque.
    Just Gary likes this.
  9. 325w
    325w
    Always use the real bolts. Said the local starter alt. Guy.
    Driver50x likes this.
  10. Driver50x
    Driver50x
    Personally, I would throw that Jegs starter in the trash and get an AC Delco mini starter. You can get them pretty reasonable from Summit or Amazon.
    swade41 and sdluck like this.
  11. I always run a brace. Actually made one for the mini starter on my 53. Seen too many snap bolts. One engine I had to pull broke starter bolts a couple times. The third time I sourced a brace for it. Magically it still hasn't broken the last set of bolts I put in five years ago
  12. blue 49
    blue 49
    from Iowa
    I don't know if really needed, but I made an adapter bracket for mine.
    Gary
  13. hotrodA
    hotrodA
    Great idea! Thanks for sharing.
  14. swade41
    swade41
    from Buffalo,NY
    I use this one on my pretty stout big block in my Henry J, it has no problems turning it over
    lumpy 63 likes this.
  15. blue 49
    blue 49
    from Iowa
  16. mohr hp
    mohr hp
    from Georgia
  17. TA DAD
    TA DAD
    from NC
    The wrong bolts and to much timing will break the nose on a old style starter in a minute, especially on a Big Block.
    VANDENPLAS likes this.
  18. 19Eddy30
    19Eddy30
    from VA
    I have not used a Support on Mini's
    Not all are made /created equal.
    OEM mini work well , down fall for Chevy Oem does not have dual bolt pattern,
    Aftermarket Non Oem hit & miss ,
    On Quality, cheap Contacts on the inside and parts used.
    Bolt Quality is a must, there is so many
    Off shelf big box stores , Ebay Amazon
    Junk , You can tell , Bolt , nuts , washer
    Etc. Buy color , look of threads , Just Junk even grade 8 , same with br***.
    I have seen Broken starter pads
    Outer bolt & pad , because of Cheap & Wrong starter Bolts ,
    & battery almost dead , To much initial timing because people do not know how to start,, with a lot of initial timing you need to start like you would with a Magneto!!
    There are different specs on starters
    Just like a Alternator,
    In One of my Applications I had to use a
    6 or 7 hp starter ,
  19. The 39 guy
    The 39 guy
    No brace on mine, (sbc and flathead) trouble free 12 years and 8 years respectively.
  20. TA DAD
    TA DAD
    from NC
    I just bought two new bolts this week from the local Chevy store, the knurling makes the bolts tight in the housing with no movement. $30.00 for 2 bolts but they had them in stock so how do you argue with that, or at least that is how I look at things. These were like 4.33 inches long.
  21. hotrodA
    hotrodA
    Thanks for all the responses.
    The starter is OEM, freshly rebuilt by starter shop I trust, with new bolts.
    Just thinking about the future. If I do anything it will be like @blue 49 ’s bracket.
