SBC miss under load
Discussion in 'The Hokey Ass Message Board' started by Dooley, Apr 21, 2010.
  1. Dooley
    Dooley
    from Buffalo NY
    Changed nothing on my car and it went from running good to a miss under load part throttle.
    If I stab it it smooths out.
    Idles revs and cruises fine but when accelerating it breaks up.
    Check a few plugs and the are right on,
    timing is good,
    wires are new
    floats are good
    Fuel pump (electric) is a year old as is filter, fresh 93 octane yesterday...
  2. KooDaddy
    KooDaddy
    from Wis.
    Maybe a problem in your exhaust system. I had a 69 Chevelle where the pipes where 2 layers and the inside layer collapsed caused the same condition. Just a thought, good luck
  3. 3onthetree
    3onthetree
    Check the mechanical advance weights in your distributor to be sure they move freely and aren't sticking or binding.
    I had this problem a couple of times and it was always the plugs. A fresh set would be cheap. One of the insulators could be cracked.
    Double check your wires again, in the dark while running, and mist a little water on them and the dist cap before you start.
  4. Dooley
    Dooley
    from Buffalo NY
    Not a bad idea on the plugs...
    I will check the wires as well
  5. nutajunka
    nutajunka
    Check cap and rotor also for carbon tracking.
  6. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Definately distributor ,Had the same problem on my Pontiac......Pull distributor and find replacement....
  7. the breakerplate in your distributor could be bad i had the one in my 351 cleveland go bad acted just as you describe
