Technical SBC not performing well
Discussion in 'The Hokey Ass Message Board' started by Rusty Heaps, Sep 16, 2022.
  1. Budget36
    Budget36
    I wonder, because I sure don’t know, what’s the difference is a solid v hydraulic lifter cam that lifters can or cannot be swapped?
    Seems like a good time to ask;)
  2. NoelC
    NoelC
  3. 427 sleeper
    427 sleeper
    Have you checked to see if all the rocker arm's are moving while the engine is running, yet?
  4. Ericnova72
    Ericnova72
    from Michigan
    Solid cam lobes are ground with a lash take-up ramp to ease into moving the lifter up the actual cam lobe....with no lash in a hydraulic lifter, the engine sees this as a huge increase in seat duration.
    Cam duration specs are just tossed out the window.
    The only mix and match that does work is solid lifter on a hydraulic cam....but the lash has to be adjusted really tight, like .002'-.006" cold....just loose enough to not hold a valve open cold and prevent the engine from running, but tight enough so the no-lash ramp hydraulic cam lobe doesn't beat itself to death from lash when running.
    There is an EngineMasters video of them running solid roller lifters tight lashed on a hydraulic roller cam and picking up a little power from it.
    (1372) Hydraulic vs Solid Lifters: The Redux!—Engine Masters Preview Episode 48 - YouTube
    Ask Away! with Jeff Smith: Can I Run Solid Roller Lifters on a Hydraulic Roller Cam? (onallcylinders.com)
    Will Solid Lifters Work on a Hydraulic Cam? (motortrend.com)
    Budget36 likes this.
  5. jaw22w
    jaw22w
    from Indiana
    Kind of a different subject, but aren't solid roller lifter sometimes used on a hydraulic roller cam? Probably has to be adjusted tight also.
  6. Jagmech
    Jagmech
    Sounds like you are lost in tall gr***, if you have not found a bad vacuum leak, stop , don't start ripping stuff apart, call a buddy who is sharp on diagnosis, or knows someone who is, and figure it out. Sounds like this motor has had some problems, and it might just be a timing chain that jumped a tooth or 2.
  7. lo-buk
    lo-buk
    from kcmo
    Newer carbs will not match the old small bore intakes.
