Technical SBC oil leak
Discussion in 'The Hokey Ass Message Board' started by billfunk29, May 16, 2024.
  1. billfunk29
    billfunk29
    from Minnesota
    Dealing with something I have not seen before. Rebuilt 283 SBC with oil that looks to be leaking from the head gasket. The bottom edge, under the spark plugs. No oil anywhere above the spark plugs. Anyone seen this? Mechanical fan, so it is hard to see where it is coming from while running.
  2. 427 sleeper
    427 sleeper
    If it's on the left side, it's probably the deck plug that's loose.
    Deuces and Bob Lowry like this.
  3. ronzmtrwrx
    ronzmtrwrx
    I’m putting some run time in on a fresh W motor and I’m seeing a similar issue. Right front corner and left rear corner. New Edelbrock aluminum heads. I thought it might be seeping out from the drain back holes but they are on the inside corners of the heads. I’ll probably be pulling them back off soon to figure it out.
    Deuces likes this.
  4. Bob Lowry
    Bob Lowry
    Yep, had the same exact issue with one of my blocks that I had sent out. Right at #7 cylinder. Bob
    tractorguy, Deuces and 427 sleeper like this.
  5. 427 sleeper
    427 sleeper
    Me too, Bob, Me too... It was my own damn fault for not checking it! :mad:
    Deuces likes this.
  6. SS327
    SS327
    It’s not leakin oil, it’s “Oozing Horsepower”!
  7. Bob Lowry
    Bob Lowry
    Ditto.
    Deuces likes this.
  8. billfunk29
    billfunk29
    from Minnesota
    Thank you for all the replies. I also got a reply from Dan Pate cluing me into the UV tracing fluid. Mix with your oil and use a Black light to illuminate. Oil path glows. In the end, it was the valve cover with a convoluted path down the head.
  9. Bob Lowry
    Bob Lowry
    Easy Pleasy! Thanks for letting us know the outcome. Too many don't. And the beat goes on....
    Deuces, Special Ed and 427 sleeper like this.
  10. Glenn Thoreson
    Glenn Thoreson
    from SW Wyoming
    Look closely at the back end of the joint between the intake manifold and the block. The rubber piece the goes across the back is easily bumped out of place when ***embling. It's a common problem, especially with the old style 4 piece gasket sets. You need to glue the rear rubber piece down to help prevent this. Permatex High Tack gasket cement is great for that. Sets fast and holds strong. If it has the joints between the rubber and the manifold gaskets, those need to be sealed, too. Last time I worked on one of these I was able to get a one piece ***embly. Don't know which is available now. It's been too many years. If that's the problem, be sure to be careful setting the manifold straight down. Hope this helps you.
    is very easy to bump out of place and is a common problem
    2OLD2FAST and Tow Truck Tom like this.
  11. Budget36
    Budget36
    I gave up on the front and rear gaskets ages ago. My buddy told me clean it off, run a 3/16th bead of black RTV.
    Never a leak…well, not there anyways;)
  12. 2OLD2FAST
    2OLD2FAST
    from illinois
    To the best of my knowledge , no one makes or has ever made a 1 piece intake manifold gasket for a sbc .
    Agree with budget36 , silicone or right stuff on clean china walls , quality gaskets on port runners. A BIT of silicone on water ports .
    To the OP , your leak is most likely coming from above , use brake clean to clean the whole area , blow it dry with compressed air , then check when running wit the edge of a dry paper towel.
    Budget36 likes this.
