Customs SBC Oil Pan
Discussion in 'The Hokey Ass Message Board' started by 3154tm, Jun 10, 2019.
  1. 3154tm
    3154tm
    Hi all, i'm trying to find a source for 4 qt. aluminum oil pans with out cooling
    fins for a 327 SBC with drivers side dip stick. the plan is to paint it to look like
    the stamped steel OEM pan. i could swear i'd seen one before but they all seem
    to have fins these days. thanks.
  2. Mike VV
    Mike VV
    from SoCal
    You talking about the cast aluminum boat pans from the 70's ?
    Haven't seen one in years.
    Mike
  3. squirrel
    The marine aluminum pan doesn't look much like the OEM steel pan, does it?
    a few have sold on ebay in the past several months, none available right now. A boat place might have one?
  4. Never been a fan of pans that can shatter if struck by road hazards.I"ve seen some badly damaged steel pans holding oil.
  5. 3154tm
    3154tm
  6. squirrel
  7. 3154tm
    3154tm
    i'd thought about that since i'm going to paint it anyway. but being lazy was trying to avoid putting any
    labor into it since they're not very expensive if i could find one. wonder what the chances are of introducing
    stress risers from grinding off the fins? one of the raps on aluminum pans is that some are prone to cracking.
  8. Never2old
    Never2old
    from so cal
    Cut and weld a steel one?
  9. squirrel
    I'd just use a steel pan, but then, I'm an idiot
    LOST ANGEL and Early Ironman like this.
  10. classiccarjack
    classiccarjack
    Far from it actually.... And a worthy point. I have had aluminum pans give me greif. I am a believer in steel pans.
    Sent from my Moto Z (2) using The H.A.M.B. mobile app
  11. classiccarjack
    classiccarjack
    I have to ask, what would be your benefit to utilizing a aluminum pan over a steel pan?
  12. big duece
    big duece
    from kansas
    Cast aluminum rails won't collapse like stamped steel ones(possible leaks) same goes for valve covers.
  13. 56sedandelivery
    56sedandelivery
    ^^^Possibly slightly better at cooling, extremely slightly^^^. Know anyone with a mill? Better than grinding, and definitely leaves a better surface. The only cast aluminum SBC pan I ever had, I gave away, and that was around 35 years ago. That red oxide primer aluminum pan looks like it might have been dropped. I am Butch/56sedandelivery.
  14. deucendude
    deucendude
    from norcal
    Don't use an aluminum pan they shatter.
  15. Torana68
    Torana68
    from Australia
    You can’t say all aluminium pans shatter , it’s not right. Cheap diecast will, quality thick cast might crack but won’t shatter. The attached will bend but also won’t shatter. It’s about the alloy and construction method.
  16. squirrel
    modern cars have been using cast aluminum oil pans for a long time...it's not a problem, if done right.
    And they can add rigidity to the block, also, if designed along with the rest of the engine.
  17. pprather
    pprather
    The risk with a cast pan in a hot rod is if you hit a high spot in the pavement it may crack. A steel pan most likely will dent.
    I've seen it happen, so be sure the alum pan is protected.
    Phil
