Technical SBC Oil Pan
Discussion in 'Traditional Hot Rods' started by Bob Bagley, May 20, 2025.
  1. Bob Bagley
    Bob Bagley
    Any of you guys had any success in removing the oil pan from a SBC while it was still living in a 40 Foad that still has stock front suspension? Thanks!
  2. wheeltramp brian
    wheeltramp brian
    I'm pretty sure that it cannot be done as the oil pan basically sits on the front u bolts.
    okiedokie, chevyfordman and Moriarity like this.
  3. joel
    joel
    Unless the firewall is dramatically modified, you can't lift the front of the engine enough for the pan to clear the crankshaft. I would remove the hood, radiator and grill and pull the engine and trans. together depending on how the trans. is supported. I am not recommending this ,however, I think that is why some people use IFS conversions. If you shop aftermarket frames, you'll notice that none are built with stock front suspension . JMHO
    bschwoeble likes this.
  4. Bob Bagley
    Bob Bagley
    The pan is only leaking in a 2 inch space on drivers' side, does anyone make an injectable sealer? I tried lowering the pan and stuffing gasket maker in the space but that didn't work. Trying to save a lot work. Thanks
  5. JD69
    JD69
    from Hockinson
    I was able to do it on my 40 with SBC. It had multiple leaks from the oil pan, timing cover and timing cover seal. I pulled the radiator, dampener, timing cover and dropped the pan bolts. I removed the carburetor and attached my lift plate on the intake manifold. I pulled the distributor to gain a bit of extra clearance at the firewall. I was able to drop the pan, but it had to be finagled out 'just so.' I ended up replacing the pan as the one I took off had distorted and cracked rails. It was still a lot of work, but I was able to get it done and get rid of the drip pan that I kept under the car.
  6. Dooley
    Dooley
    from Buffalo NY
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    There are many , many iterations of SBC oil pans , stock & aftermarket , depends on the pan you have I'd guess
    JD69 likes this.
  8. Bandit Billy
    Bandit Billy
    I did not build these cars for you to put SBC's in them and expect to pull the oil pan off without removing the engine! :cool:
    joel, Budget36 and Blues4U like this.
  9. Blues4U
    Blues4U
    from So Cal
    ^^^ :D:D:D^^^
    2OLD2FAST likes this.
