SBC Parts
Discussion in 'Parts For Sale' started by pila38, Sep 8, 2024.
  1. pila38
    pila38
    City: Burlington
    State: New Jersey
    Price: $1
    Small block Chevy stroker parts. All are very low use or brand new, never used. Went a total different direction with my engine and am not using these.
    Eagle Cast Steel Crank: 3.75” stroke. 350 main and rod journals. 2 piece rear main seal. External balance. Light Use $250 (Have the balancer and flex plate to go with for $100 more)
    Eagle SIR Connecting Rods: 5.7” length. Bushed. Light Use $325
    Wiseco Pro Tru Forged Pistons: Flatop. 4.030” bore. 1.425” compression height. Includes wrist pins, spirolox, and JE Piston Rings. Brand new $575
    Summit CT108 solid flat tappet cam: Advertised Duration 282/286,
    .050 Duration 248/251, Lift .531/.542, with lifters. Brand new $200
    Comp Cams Valve Springs 987-16: Dual, 1.430 in. Outside Diameter, 370 lbs./in. Rate, 1.150 in. Coil Bind Height, Set of 16. Brand new $100
    Summit G3602 Oil Pan: 6 qt, 2 piece rear main seal, Baffled, windage tray, scraper, stroker clearanced, passenger dipstick. Includes G3620 pickup for standard volume pump. $275
    Pete Jackson Gear Drive: Used $75
    World Sportsman II heads: 64CC, 2.02/1.60 valves. Heads are disassembled, but I have the valves. Porting was started, but never finished, bought better heads instead. $400
    80’s 350 block: Rough bored to 4.055, ready to go to 4.060. Block has a small heat crack between cylinders 4 and 6. Machinist said it’s good for a cruiser motor, but that doesn’t fit my plans so went with a different block. $100
    Didn’t get pics of everything, but can get them on request IMG_5159.jpeg IMG_5160.jpeg IMG_5161.jpeg IMG_5163.jpeg IMG_5164.jpeg IMG_5165.jpeg IMG_5166.jpeg IMG_5167.jpeg IMG_5168.jpeg IMG_5169.jpeg IMG_5170.jpeg IMG_5172.jpeg IMG_5173.jpeg IMG_5174.jpeg IMG_5175.jpeg IMG_5176.jpeg IMG_5178.jpeg IMG_5179.jpeg IMG_5180.jpeg IMG_5181.jpeg IMG_5182.jpeg IMG_5183.jpeg IMG_5184.jpeg
    1Nimrod likes this.
  2. pila38
    pila38
  3. pila38
    pila38
  4. pila38
    pila38
  5. pila38
    pila38
  6. pila38
    pila38
  7. pila38
    pila38
  8. pila38
    pila38
  9. pila38
    pila38
  10. pila38
    pila38
