SBC Power steering....Need to slow it down!!!!!!!!!
Discussion in 'The Hokey Ass Message Board' started by ROADRAT EDDIE, Mar 26, 2009.
  1. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    '55 F100, 305 and a Camaro front clip....Essentially a stock Camaro with an F100 body and the power steering is waaayyy to fast without any road feel....Did GM make different pumps?....Different size pulleys on their pumps?....Inquirering minds want to know how to slow it down:mad:
  2. Stick004
    Stick004
    from Missouri
    I know this is completely unhelpful and probably rude... but I feel it must be said.
    I feel sorry for that old F-100.
    You could try using a pump from near same year chevy truck. But being as it is virtually a stock camaro. I don't see how it could have gotten so far off.
  3. Revhead
    Revhead
    from Dallas, TX
    pump won't change how fast it turns. You need another gear box. and they made several in in different turn ratios.
    first find out what gear box you have. look for casting numbers.
    also turn the steering wheel completely to one side and then back to the other counting how many turns it takes. if it is a first gen camaro, 4.5 turns is a stock base model. 2.3 turns is '69 variable ratio. The gear box will also affect the "feel" and how much assist the box gives. Unfortunately usually more feel goes it quicker turning for the performance cars.
  4. MIKE47
    MIKE47
    from new jersey
    Eddie, It ought to feel just like it did in the Camaro. Are you using the factory hoses too? Or did you get custom ones made? Maybe they had a restrictor in there somewhere? I can't see the box being the issue, but what is it's ratio? Compare that with others and see if yours is, for some reason, too fast. Does it turn real easy sitting still too? maybe getting full assist all the time? I'd be more likely to believe that It's getting full pressure when it shouldn't be. Maybe the pressure valve in the pump is stuck? I am assuming that the pitman arm and all are from the Camaro, right? Changing something like that would change basic geometry. Even if you had a large steering wheel I would think it would be close to the same.
    If you are totally stumped reach out to someplace to Borgesen's to see if they can help.
  5. The size of the steering wheel may also help. If it's small it will turn faster than a larger one. I know this may be a minimal difference but still a difference.
    BloodyKnuckles
  6. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    As far as i know. it's all stock Camaro, including the hoses...{Sorry Stick. i didn't build it...It is what it is}....The wheel is a '56 Chevy so it's a big wheel....The feel of this thing reminds me of 60's-70's Chrysler which i remember feeling way over assisted
  7. choppintops
    choppintops
    Yes, it was. No, it didn't.:cool:
  8. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    I'm also thinking of stepping up in tire width...Would this be a noticeable difference, say i went from a 195 to a 225?
  9. So is the problem too much assist or too fast of steering - they are two different things with different solutions.
  10. 4woody
    4woody
  11. brigrat
    brigrat
    from Wa.St.
    Hope you don't have your front clip installed way to straight up an down, check your camber & caster ..............................
  12. ROADSTERJEFF
    ROADSTERJEFF
    You can add a plate to the back of the pump at the pressure end. It is orfice plate I got one for car at the local speed shop it was less than 20 bucks!
  13. billbrown
    billbrown
    different companies make adjustable valves to "firm" up the feel, but unless you went with something like the magnasteer in newer gm trucks and some cars, you will just have to deal with you super assited steering.
  14. That's what I'm thinking... Do the wheels center themselves when you come out of a corner? Do you have to hold the wheel in a straight line while going down the road?
    http://www.ozebiz.com.au/racetech/theory/align.html
  15. brigrat
    brigrat
    from Wa.St.
    Put an angle finder on the top of the top "A" arm, tell us what it says..................................
  16. Mopar34
    Mopar34
    I'm a little surprised by this problem since you moved the entire front clip form the Camaro over to the pickup.:confused: I would have thought the steering would feel about the same. Usually this is a problem when someone uses a GM pump with a Mustang II power rack. In any case, you can try one of the adjustable valves from any number of dealers such as Speedway or Heidt's.
    I've also been told that a power steering pump rebuilder can rebuild your pump for what ever steering ratio you want. IF that's the case you check your yellow pages for a rebuilder.
    Short of that you can just learn to steer fast and keep alert. That's what I did.:eek::D
  17. 29nash
    29nash
    from colorado
    Smaller pulley on the front of the crankshaft damper to turn the steering pump will slow it down.
  18. ROADRAT EDDIE
    ROADRAT EDDIE
    from New york
    Too much assist
  19. MIKE47
    MIKE47
    from new jersey
    Easy way to fix would be some restriction as stated. That Speedway valve looks like an inexpensive thing to try. Cheaper than tires for sure. That is assuming all the alignment stuff was ok.
  20. brigrat
    brigrat
    from Wa.St.
    Like said before, this is usually a problem with GM pump to MII rack if it's a geometery/setup problem the restriction/valve thingy will only be a bandade ............ JMO
  21. I agree that I would look at caster setting in particular before adding one of the valves I listed, but by the same token I always thought those Camaro's were way over assited stock!
  22. Berzerk
    Berzerk
    "I know this is completely unhelpful and probably rude... but I feel it must be said".
    I often wonder how many new members have questions that could be answered by all the knowledgable people on this forum, but never ask because they are affraid someone will post a comment reflecting their own feelings and opinions. Unless someone seeks opinions about their vehicle or project, don't give yours...
  23. RAY With
    RAY With
    OK been there done that--Easy FIX and here is the way--Remove the pressure regulator-Thats the big nut where the pressure line screws in--It will have a tube on the back attached to the nut--Take a hack saw and about 3/16 from the end cut a straight cut (like your going to shorten it)--- Cut a little less that 1/2 way through--Remove hack saw and go back about 1/8 inch and angle cut it to the first cut--It will look like a whistle--thats it-We did this on circle track cars with PS to reduce the pressure and get wheel feel again
  24. Drive Em
    Drive Em
    Stick some caster in it, say 8 degrees or so, it will feel way better.
  25. 2-TONED
    2-TONED
    is the problem when you are on the highway 60-70+ mph?
    i have driven cars with toooo fast of steering on the highways. i hate it!
    my 34 ford truck drove AWESOME & straight as an arrow on any highway or 2 lane 65 mph & under one thumb on the wheel & i was very relaxed
    but once over that 65 mph i was 'ALERT' drove good but i had a grip on the wheel.
    i had a short pitman arm ------ i changed to a different steer box now with a longer pitman arm ill know in a month when i get it back out & ill fuk with that front end everyday until im relaxed & very comfy at 100.
