sbc problem solved
Discussion in 'The Hokey Ass Message Board' started by racer-x, Jul 14, 2013.
  1. A while back i asked for advice on a oil leak on my 327. I thought it was a rear main seal. After replacing it a few times i borrowed a smoke machine. With the flywheel off the moroso deep pan lip was visible. It turned out to be the contour of the pan. Some gentle m***aging later the leak is gone. A friend told me he had a similiar leak but in the front. Just thought i would p*** this on in the hope it helps some one else.
  2. aaggie
    aaggie
    Even with a brand new pan it is a good idea to lay a straight edge across the sealing surface and make sure it is flat. A few minutes with a hammer and dolly will save a lot of grief.
  3. racemad55
    racemad55
    Okay ,whats a smoke machine?
  4. Saxman
    Saxman
    x2 !?
  5. waterhorse
    waterhorse
    Well, it's a machine that produces................smoke.:D
    Seriously, I think he is refering to a smoke generator you would use for special effects such as for Haloween decorations.
  6. saltflats
    saltflats
    from Missouri
    I think thay came up with the smoke machine to fine va***e leaks on the newer cars to try and fix them pesky evap codes.
  7. spinout
    spinout
    from Dallas, TX
    I've seen smoke machines used to track down vacuum leaks on engines. If there's a leak, the smoke will pour out.
  8. O K how does it help find a oil leak?
  9. Baumi
    Baumi
    smoke machine... well , what´s left to say?
  10. Grudge
    Grudge
    Harmless white smoke is pumped into a closed system under a small pressure. The smoke exits through leak paths. They are a great luxury diagnostic tool.
    Aaron
  11. falcongeorge
    falcongeorge
    from BC
    I ***ume you are saying it was leaking on the rounded contour at the rear main cap?Man, that could have taken forever to find through conventional means.
  12. Saxman
    Saxman
    Well, that sounds pretty cool. I've never heard of it before. Glad it worked.
  13. saltflats
    saltflats
    from Missouri
    I watched a show on HP TV that had a engine builder from? that would test fit the pan and then sand down the end seal to fit. I guess if you use studs for the pan at the ends it would show the misalignment of the end seals.
  14. 55 gasser pickup
    55 gasser pickup
    from utah
    . X2 I used one at a shop I used to work at.Nice to have around.we would fill it with Baby oil and it heats the baby oil up to make the smoke!
  15. spiderdeville
    spiderdeville
    from BOGOTA,NJ
    yeah , and use a torque wrench
  16. Hotrodmyk
    Hotrodmyk
    that's a SMOKE MA-CHeen;)
  17. Deuces
    Deuces
    Kinda grabs you by the boo boo don't it???..
    ..........Thomas Chong:D
  18. go-twichy
    go-twichy
    I've got to fix my car, where's the mirror ball?
  19. Atwater Mike
    Atwater Mike
    When the Chevy fire seems to go out...Just add smoke!
  20. Nah, that's a FOG machine.......same one they used in cheesy rock videos in the 80's :D.
  21. saltflats
    saltflats
    from Missouri
    Wish I had a fog machine in the shop for when the bull **** and beer drinkin started.
  22. DoubleJ52
    DoubleJ52
    from Belton, MO
    A smoke tester is a machine designed to find leaks as small as .020 of an inch in OBD II EVAP systems and has become very helpful in finding vacuum leaks and in the case of OP an oil leak he was having trouble fixing. It uses nitrogen and a special fluid that produces "smoke" that can be seen with a high intensity light.
  23. mustang6147
    mustang6147
    from Kent, Ohio
    ^^^^^ there ya go
  24. saltflats
    saltflats
    from Missouri
    Yes the ones that use nitrogen are rated for newer cars the one that you hook up to the air comp are not but work for lots of things. **** $$$
  25. There are also smoke Pencils, we use the for testing laminar air flow hoods. Great way to determine air flow paths.
  26. the way it works is a hose goes into the dip stick thats where the smoke is pumped into the engine. the breathers must be plugged. as the pressure builds in the crank case it wants to exit the engine. the path it takes to get out is the area of the leak. they can also be used to find a water leak on a interior. door or window etc. or pesky wind noise. i learned about this through my son when he had auto shop cl***. glad i could help out.
  27. icsamerica
    icsamerica
    I set my air regulator to 5psi and pressurize the crank case with shop air . Then Use some soapy water in a spray bottle to find any leaks. There nothing wrong with a smoke machine but my garage is only so big.
