Projects SBC question about a starter
Discussion in 'The Hokey Ass Message Board' started by Tom Noller, Nov 14, 2015.
  1. Tom Noller
    Tom Noller
    from Iowa
    Guys, I'm new to the message board and am in a bit of a quandry over mixing and matching parts on a project car. I've got an 80s Chevy 350 with a T-5 (non world class) behind it, in the chassis of a '54 Kaiser Manhattan. The guy who sold me the******* also gave me a bell housing that fit it. Turns out to be a truck version (#3925505) and I have to use - after searching the web - a 3635S type starter that bolts to the housing and not the block. This, after trying to install a later starter and realizing it wasn't going to work.
    I'm using a 168 tooth flywheel and wondering if a 9-tooth starter would work with it? Thanks! PICT0214.JPG
  2. why can't you use the normal staggered bolt hole starter that's for the 168 tooth flywheel?
  3. squirrel
    55 to 72 vintage truck bellhousing works with the 168 tooth flywheel and the truck starter. The later two bolt starter may or may not fit.
  4. gas pumper
    gas pumper
    Try the later starter.. I did exactly the same and my starter that fit the engine block fit right into the hole in the early bell. NO modifications needed.
    Maybe I was lucky and Jim is right, it might not work on yours. But mine is perfect.
  5. big duece
    big duece
    from kansas
    If you have the truck bell housing, does it register properly with the front imput bearing support? If not I have a car bell housing I can sell you.
  6. squirrel
    Usually the truck bellhousing thru 67 has the small hole for the bearing retainer, and 68 up had the large hole.
  7. Tom Noller
    Tom Noller
    from Iowa
    Thanks, Guys! My later starter, with the two long bolts into the block, doesn't fit.
    I think this is what I need: http://tinyurl.com/ovejts8
  8. FritzJr
    FritzJr
    You could just change the nose on the starter that you have, if you can find an old starter with the proper nose.
  9. big duece
    big duece
    from kansas
    Thank you for making that clear, I thought there was a change sometime.
  10. Mr48chev
    The truck bellhousing snouts are readily available and are steel or cast iron plus the keep the register to the flywheel right on the money.
    That said I have seen guys using the bolt to the block starters grind the corner of the bellhousing that gets in the way enough to clear but personally I'd prefer the bolt to the bellhousing setup.
    Using the O'Reilly cheat sheet the starter does use the 9 tooth drive.
    They just show the starters and no end piece but you should be able to find one of those easily http://www.oreillyauto.com/site/c/s...ickup+RWD&vi=1321096&year=1967&make=Chevrolet
  11. squirrel
    $50 in stock, yeah, they're not hard to find.
  12. bobss396
    bobss396
    Definitely bolt the starter to the bellhousing. I have been using the same truck set up for many years and just had my OG starter rebuilt and converted to a high-torque.
    Go to an auto-electric shop, they may have the right one on the shelf and you pay the core charge (usually cheap). Truck 'yards are full of them as well in case you need a core.
  13. squirrel
    OReilly's has the core in stock for a mere $15, no searching required.
