Technical SBC ramshorn exhaust manifold ( Update )
Discussion in 'The Hokey Ass Message Board' started by 48stude, Mar 9, 2017.
  1. 48stude
    48stude
    I'm using 2 1/2" Ramshorn exhaust manifolds on my roadster. Originally you would use a doughnut with a flared exhaust pipe and a slip flange. Getting those pieces here locally is like finding hens teeth. Is there an alternative such as a flat gasket and a stationary flange . Has anybody used something else that worked ? Thanks, Bill
  2. squirrel
    maybe post a picture or link showing the exact manifolds you have? Some have a flat surface to mount a heat riser valve, some have an angled flange for the donut (often the pass side has provision for heat riser, driver side does not).
    If there's enough flat surface, you can use a flange and gasket, but it would want to be a thick flange, so it won't warp.
  3. I wouldn't thing the flange and doughnut gasket would be that difficult to find. Most exhaust shops have those parts.
    Sent from my E6782 using The H.A.M.B. mobile app
    hillbilly likes this.
  4. bowie
    bowie
    Any Corvette Resto parts outfit that does mid year cars should be able to supply the original style.
  5. 56shoebox
    56shoebox
    Have you tried rockauto.com?
  6. 48stude
    48stude
    Here's a picture Jim . These are imports
  7. slowmotion
    slowmotion
    Both local Napa & Advanced list 'em here. Neither in stock though, have you tried calling the stores in Weirton?
  8. squirrel
    You could probably get away with a flange and gasket on those, but use a good thick flange, and a good gasket.
    The original setup has a donut, and inner tube, and an outer tube with the flared end, and the flange that holds it all in place.
    although there are metal donuts, and metal core composition donuts available. I've seen several instances where an exhaust shop doesn't include the inner tube, and the donut slowly collapses and won't stop leaking.
  9. 48stude
    48stude
    I went to the local Monroe muffler ,I took the chrome manifold . I asked the guy if he could flare a short piece of pipe and did he have a doughnut and slip flange ? What is this for? I say it's for a 327 sbc that is in a Model A roadster. I get the deer in the headlight look:eek: So I tell him that an early to mid sixties Corvette is close to the same. He says our machine is broke and the company won't fix it because there isn't enough demand( this is my translation ) Ok , would you happen to have the doughnut and a slip flange ? No we don't carry anything like that. You might check Advance Auto down the street. So I go into Advance Auto carrying this chrome exhaust manifold and ask for a doughnut . What's this for ? Try a mid sixties Corvette with a small block. He goes in back for about five minutes and comes back with a modern style half doughnut. I says that won't work , needs to be a doubled sided doughnut . Well the only thing we could do is try to order some thing from headquarters. I said I'd check back. . There is another muffler shop in town that I went to about fifteen years ago and asked for two pieces of mild steel exhaust one 2 1/2" and one 3" both 4' long . He gives me nasty look and says yea I got that, it will be $100 . I just turned and left vowing that I would never go there again
    NoSurf likes this.
  10. 48stude
    48stude
    I'm I totally agree with ya Jim Thanks , Bill
  11. squirrel
    Apparently, this is rocket science... :)
  12. 48stude
    48stude
    Yes, I was in Weirton yesterday. Where are you located? Bill
  13. 48stude
    48stude
    Jim, Locally , You would think this to be true:rolleyes: Bill
    Truckdoctor Andy likes this.
  14. Rex_A_Lott
    Rex_A_Lott
    I know you see different things in different parts of the country, but this blows my mind. Has it really been that long since nearly everything on the road had this type of system? Every exhaust shop did this all day every day?
  15. 48stude
    48stude
    Around here, when you go into any business and they ask what's this for and you say ( fill in the blank ) hotrod ,street rod , race car. You're already in trouble. 95% of the time, to them you are wasting their time (and yours) My trip to Weirton yesterday was a waste of my time except for buying a 7/8" dowel rod at the Busy Beaver so I can mock up a steering shaft. Bill
    RollinRock and upspirate like this.
  16. squirrel
    I know what you mean. I always look up parts on the internet before going to the parts store.
  17. indyjps
    indyjps
  18. 48stude
    48stude
    Let me show you guys the whole story
    gimpyshotrods likes this.
  19. Ummm-Is that the new motor mount by 'Skyhook Industries'?
    The exhaust can be cured with some(ghast...) block huggers or tight mounted full length headers-but that's not what you want to hear-might need another piece of steering shaft,another universal and a bearing to get under the exhaust flange.
  20. gimpyshotrods
    gimpyshotrods
  21. 48stude
    48stude
    As you can see ,I need to make a very sharp turn right away. I'm thinking even if I had the proper pipe ( with doughnut, flare and slip flange ) there isn't enough room to make the bend. If I can use a flat gasket and heavy flange ,I can start the bend quicker ?? . Here's the rest of the story. I could use blocker hugger headers but I don't have anything against them , I just don't want them on this car. I could even use later sbc exhaust that dumps toward the back, but not on this car. I could use lakster style headers but only as a last resort . I'm not that fond of the sound of baffles and I'm not fond of the exhaust dropping down to slip under the frame , especially on a 32 style frame. It blocks the scenery if you know what I mean. I like that on a channeled car but mines not channeled. I sure am blowing a lot of hot air it seems:D Thanks to you guys. Bill
  22. squirrel
    Or move the steering box back to where it belongs.
    hillbilly and Hnstray like this.
  23. 48stude
    48stude
    I bought them at Summit. Energy Suspension . Bill
  24. 48stude
    48stude
    Cross steer, Vega box
    I have the drag link set up parallel to the tie rod on both planes( looking down and looking back from the front)
    Isn't this right ? Bill
  25. gimpyshotrods
    gimpyshotrods
    Here's what I would do:
    For now, pull out the steering shaft and u-joints. Put them aside for later.
    Get, or, or make, a copper gasket that will fit the manifold flange, and and exhaust flange that will attach to it. I realize that you were going the doughnut route, but you have a severe space issue, and they will be a liability.
    Get three 90º mandrel bent elbows, bent on the tightest radius that you can get.
    On the first one, cut off just about all of the straight part on one leg.
    Put the three bolt flange on the manifold, and tack weld on the that first 90º elbow with the horizontal leg pointing at the point where the oil filter pedestal meets the main body of the block.
    Take the second 90º elbow and shorten its legs so that you can attach it to the first elbow, without it getting either too close to the block, or blocking where the steering shaft will go.
    Attach the third 90º elbow, shortened as necessary, to make the run to the rear of the car.
    Then, shorten your steering column tube so that it is much closer to the firewall. Put the u-joint back on, add a support bearing, and another u-joint, and then finish the run to the box.
    BJR, scotty t, Kan Kustom and 3 others like this.
  26. Mo rust
    Mo rust
    Could you use the rams horn manifolds off of a pickup that sweep back?
  27. treb11
    treb11
  28. digging through some more pics... maybe this helps maybe it doesnt. Hard to tell but looks like your engine sits lower. I have no trans hump or firewall setback, with my 327/T5 so you should have room to raise it... might help ya out in a couple ways.
    -Tub is a couple states away right now or i would snap you a good picture...
    Screen Shot 2017-03-09 at 12.34.41 PM.png Screen Shot 2017-03-09 at 12.37.25 PM.png Screen Shot 2017-03-09 at 12.37.52 PM.png Screen Shot 2017-03-09 at 12.39.44 PM.png
  29. treb11
    treb11
    That's what I'm using with my project and they make a world of difference versus the straight down dump.
  30. 48stude
    48stude
    I was thinking that we were pretty close . I was going by the height of your distributor in relation to the gas tank flange. If you are running a Delco type distributor.
