sbc runs better retarded than advanced?
Discussion in 'The Hokey Ass Message Board' started by Dynaflash_8, Apr 17, 2010.
  1. larry_g
    larry_g
    What you say in the part I quoted is correct, The rest is also correct but pertains to setting the distributor. Go back and read the part of the post you responded to that I took exception to. The OP has no timing mark and the discussion is to help him establish one, not install the distributor and static time it for operation. To establish the timing mark on an engine you have to determine TDC of the piston, #1 in a SBC, and then make your mark and a pointer that will be stable in operation. After the mark and pointer have been established then all you say is true to install the distributor.
    lg
    no neat sig line
  2. ClayMart
    ClayMart
    You're absolutely correct as well. Went back an re-read the OP and it looked like he might be having three or four different issues to contend with. I think it's just a matter of you looking at it from one angle and me from another.
    Looking just at crank position with no regard to the cam or distributor, TDC #1 is TDC #1 pure and simple! :D
    Not surprisingly I kind of over ****yzed things, figuring before it was all said and done the distributor might be in and out of it a couple times and the cap rewired as well. :eek:
  3. Hitchhiker
    Hitchhiker
    you have no clue who that is do you.....
  4. Parts48
    Parts48
    from Tucson, Az
    I heard the guy was a grump....
  5. The 41Dude
    The 41Dude
    Bill Grumpy Jenkins?
  6. mac762
    mac762
    Shhhhhh........
  7. hotroddon
    hotroddon
    Funny that the OP has never commented back on responses to his questions .........
