Customs SBC short pump alternator bracket help needed
Discussion in 'The Hokey Ass Message Board' started by txcr13, Mar 22, 2017.
  1. txcr13
    txcr13
    Running short water pump, with driver side alternator. Looking for a cast iron Corvette/pickup style lower bracket and upper brace. Want to keep factory look...no billet mounts...if possible.
    Will not have power steering or AC.
    Will appreciate help with part numbers or sources.
    Thanks!
  2. Montana1
    Montana1
    You mean like this? I just took this picture to a bone-yard and showed them what I wanted and they fixed me up.
  3. gimpyshotrods
    gimpyshotrods
    Check Eckler's Corvette Parts.
  4. squirrel
    new ones are expensive! I like the boneyard idea.
    Montana1 likes this.
  5. gimpyshotrods
    gimpyshotrods
    You guys must have better yards out where you are. Here, it is late-model, or it is gone.
  6. 19Eddy30
    19Eddy30
    from VA
    How about a monza V8 style.It will move it to p*** side like 69 Camaro
  7. txcr13
    txcr13
    Yes sir, that is exactly what I need!
    Can anyone help narrow down the application that mount and arm came from?
    Thanks to all.
  8. rusty rocket
    rusty rocket
    You can also check into Alan Grove brackets. They are steel, they move the alt. up on top instead of hanging off the side. Just a thought.
  9. 1955hb
    1955hb
    from nebraska
    try the truck venders
  10. Fordors
    Fordors
    Agreed^^ I gave up on the yards around here years ago. If they did have early SBC stuff it was roped off and off limits to visitors. Everything went to one guy with an inside deal with the yard owner.
  11. wraymen
    wraymen
    Header mount bracket might work.
    Just Gary likes this.
  12. 57 HEAP
    57 HEAP
    This type will work, less the bracket with the slots, with a cast iron manifold.
  13. squirrel
    The one you want was used on Vettes and trucks, starting in the late 60s.
    3951337
    Trucks used it from 69-72 on the 307 and 350. Vettes from 72-82, from what I can tell.
    It bolts to the end of the head, so it won't work on most 1968 or earlier heads
  14. Montana1
    Montana1
    I want to say these brackets came from a '70-'72 Chevy C-10, '73-'81 C-3 Corvette, if I remember correctly.
  15. aerospace_adams
    aerospace_adams
    Did you find a bracket? I have one I pulled from a mid-70's Corvette sitting on my desk in my shop that I don't need. I can post a picture tonight if you are interested.
    James
