SBC Short vs Long water pumps
Discussion in 'The Hokey Ass Message Board' started by panhead_pete, Nov 23, 2009.
  1. panhead_pete
    panhead_pete
    Did a bit of research and just need to check that the difference between short and long water pumps will be
    a) the pump
    b) the pulleys
    Anything else?
    Will not be running mechanical fan, only water pump and low slung alternator.
    Thanks guys.
    Tow Truck Tom likes this.
  2. skunx1964
    skunx1964
    nope nothin else, just need to get the right brackets and pulleys for whichever pump you go with....
  3. squirrel
    Originally, the short pump engines had the generator/alternator on the left side of the engine, hanging out in the breeze, the long pump had it on the right side, tucked in front of the head. The long pump gives more room to put the alternator closer in
    Tow Truck Tom and ekimneirbo like this.
  4. panhead_pete
    panhead_pete
    Ah thats one of the reasons I was going to do it, seems I have this *** about :(
  5. Also, the corvette short pump has a 3/4 pilot, not the more common 5/8 pilot for the fan and on the short pump alt mounting, the driver exhaust manifold was the lower mounting and when going to headers the cheesy aftermaret " bent steel" brackets have a history of breaking, but if your cylinder heads have the holes in them, then you can use corvette short pump (thru '81) alt mounting as it bolts to the front of the head and are avaliable in steel or aluminum.
  6. panhead_pete
    panhead_pete
  7. panhead_pete
    panhead_pete
    Thanks guys. More learnt.
  8. Ayers Garage
    Ayers Garage
    Fellas, no reason to seek out Vette brackets. The 69-72 trucks used a similar bracket and they are common and cheap. Here's one on my 327.
    MCjim, X-cpe and tb33anda3rd like this.
  9. Hi!
    Hi!
    from SoCal
    If you have the room the long pump is better. It has more options for brackets, pulleys and easier to source. If not go short.
  10. Xdrag48
    Xdrag48
    Have you checked Allen Grove's setups? He has different mounts for alt,p/s, and a/c long or short pumps... Here is the link below First two pictures are short pump,last two are long pump...
    http://www.alangrovecomponents.com/Catalog.htm
    Steve
    72yenkonova likes this.
  11. revkev6
    revkev6
    from ma
    anyone have a different factory genny setup than off the exhaust manifold?? I'd like to run hood sides on my 32 but that's not gonna happen with a generator hanging in the breeze.
  12. atomickustom
    atomickustom
    You might not care about this, but the short pump is considerably lighter than the long pump.
    Thanks for the tip, Ayers Garage, I'll be looking for one of those brackets now.
  13. yellow wagon
    yellow wagon
    from WI
    and what bracket do you use for the upper mounting then if u go with the lower like Ayers posted?
  14. squirrel
    I"m wondering what exhaust you use
  15. Yep, same bracket, just called "vette bracket" like a lot of things as they are used in several other applications and of course the vette from 79-81 used a similar bracket except it is aluminum which may or may not help with the style.
  16. Ayers Garage
    Ayers Garage
    Sorry for the busy picture, this is a powdercoating job I did for someone. You can see the upper alternator bracket in there too as well as the lower bracket if you look hard in the picture. It's generic 69-72 truck stuff. Dirt cheap to buy.
  17. yellow wagon
    yellow wagon
    from WI
    ^ excellent. I already have an upper hockey stick from a 64 Imp that looks the same as the one you posted.
  18. panhead_pete
    panhead_pete
    Thanks was on the Alan Grove site last night and will probably be ordering the second of the 4 pics above. Going with the short style pump as I need to buy all these parts and am looking for ways to maximise room initailly as will be fitting a little 144 blower :)
    Lakes Headers.
  19. Eyeball
    Eyeball
    I am running a short pump with an early wc4d intake with the oil filler tube on the front. I like this bracket but wonder if it will clear the fill tube?
  20. brady1929
    brady1929
    great info as always
    Hatchet likes this.
  21. i would say no, i'm planning to try this set-up
    http://www.waldenspeedshop.com/jitney.html.
  22. Deuce Roadster
    Deuce Roadster
    The short pump is 1 and 3/8ths of a inch shorter than the long pump.
    The Alan Grove bracket sits the alternator up a little and also moves it closer to the center of the engine. I had one on my 40 Ford with a SBC. Great bracket at a very reasonable price. :D :D
  23. Parts48
    Parts48
    from Tucson, Az
    Nothing fancy..just made two brackets. Had no room left or right..and the nose narrows so much up front. This was the only way..
  24. old post but whats that powersteering pump out of?
    [​IMG][/QUOTE]
  25. I bought these mid mount brackets for $70, fits nice, made in USA
    and the same size belt on both sides
  26. Kan Kustom
    Kan Kustom
    Glad this thread was brought up.
  27. treb11
    treb11
    Short or long pump. That's what I've been looking for. Who is the supplier?
  28. oldtom69
    oldtom69
    from grandin nd
    no one mentioned but some custom timing covers[finned alum.etc]need the long pump
