Technical SBC Short Water Pump Balancer question
Discussion in 'The Hokey Ass Message Board' started by DirtyDave, Sep 25, 2015.
  1. DirtyDave
    DirtyDave
    Mocking up an SBC using a foam block and fake 8" Balancer with a short water pump.
    The balancer hits the pump.
    Seems that a 6.75 balancer would solve that?
    I like the look of the short pump in a pre 68 car. I have the correct pulleys also. I want to be as informed as possible when I contact the engine builder (he may already know) who is typically building long pump combos as far as I can tell.
  2. 34toddster
    34toddster
    from Missouri
    A lot of 8 in balancers before 69 that didn't hit the pump???
  3. DirtyDave
    DirtyDave
    Hmm? Likely my fake balancer isn't correct. I believed it was since the fake engine is very good.
    And to clarify, the balancer hits the pulley not the pump, apologies.
  4. Sometimes all it takes is the switch to real parts from mockup parts. I have used foam blocks for mockup and have discovered that not all foam blocks are created equally.
  5. bobss396
    bobss396
  6. 325w
    325w
    Why not use the small balancer?
  7. DirtyDave
    DirtyDave
    Not sure of the casting number, but it is definitely the short style, hugs the timing cover. I bought it new at big name parts store, probably told them 68 Camaro. 011.JPG
  8. DirtyDave
    DirtyDave
    The engine builder will choose the balancer. I have ***embled a couple engines but on this build I will go turnkey, broken in, dyno tuned, ready to run.
  9. aaggie
    aaggie
    Doesn't it figure that if the builder dyno tunes and it is ready to run then the builder will supply the correct balancer and pulleys?
  10. DirtyDave
    DirtyDave
    correct, his site only showed long pumps and billet pulleys. When I reached him by phone he confirmed we can go short with painted pulleys. I was concerned that the short pump cars had some older style balancer.
  11. nobux
    nobux
    I have two SBC running 8 inch balancers and short water pumps with no balancer-pump clearance issues. On some low mount alternator brackets or power steering brackets , you'll have to do a little grinding to clear the big balancer.
