Technical SBC short water pump
Discussion in 'The Hokey Ass Message Board' started by ChucksCrib, Sep 29, 2015.
  1. ChucksCrib
    ChucksCrib
    from Uranus
    Working on the pulleys and belt on my sbc. I noticed the crank pulley is 1/8" closer to the block than the water pump pulley. Hence my belt is out of line by that much. Upon further inspection I discover the pressed on pulley mount on my short water pump which should be 5.625"(dimension used to measure a small water pump) away from the pump mounting /mating surface is actually 5.875 away.
    Question is.......is there a way to slide that mounting collar down the shaft a little more using some type of tool like a balancer install tool or something.
    thanks,
    Chuck
  2. RICH B
    RICH B
    Normal way is to take the back cover off the pump, support the impeller end of the shaft, and press the hub on to the correct location.
    gimpyshotrods likes this.
  3. ChucksCrib
    ChucksCrib
    from Uranus
    Press it on?....any chinese tool specifically designed for this or will a hammer and socket suffice?
  4. aaggie
    aaggie
    Hammer and socket will probably work, hit it gently so you don't go too far. You could also put a spacer between the crank pulley and balancer. Speedway and others sell a three piece shim pack for lining up pulleys.
  5. HOTRODPRIMER
    HOTRODPRIMER
    Or use a thick washer to space the pulley out,I've done that in the past and less likely to damage the impeller. HRP
  6. bobss396
    bobss396
    Definitely go with the shimming option over diving into the pump innards.
    Hotrodmyk and i.rant like this.
  7. squirrel
    It's been years, but I seem to remember finding pumps with slightly different heights.
    If you press the hub down, think about how you're going to replace the pump when it starts leaking, and you're not near a press.
    lothiandon1940 and norms30a like this.
  8. rtp
    rtp
    Read what Rich B said take the back off the pump use something to support the back of the shaft ,use a press to move the pulley mount to the right spot ,go slow don't press to far, You could try the hammer and socket with the pump mounted on the motor ... BUT you will have to replace the pump later when the impeller wears out the back cover. If you don't want to remove the pump use the spacers .
  9. read what rich b and rtp said
    done it many times
  10. ididntdoit1960
    ididntdoit1960
    from Western MA
    wasnt there some oddball corvette pumps that were a little longer than a "short" pump but way shorter than the long pump? FWIR it had a larger diameter shaft too
  11. ChucksCrib
    ChucksCrib
    from Uranus
    Yeah....and I have one of those pumps on an '88 roller block I have in another vehicle...it is also a reverse flow unit used with serpentine systems.
    No way I would attempt using the socket and hammer with the pump on the motor or without taking the back cover off and supporting the other end of the shaft.
    Thanks boyz.....I'll be giving that a shot. Heating up the pulley mount couldn't hurt either before wacking it.......easy, still talking about the water pump here fellas
  12. 325w
    325w
    Is this rebuilt? If so go back and ask to measure some other short pumps
  13. Hdonlybob
    Hdonlybob
    I just went with a correctly made shim last Saturday...got it from a friend, but he bought it aftermarket somewhere...do a search..it is a simple, easy, and correct fix..
  14. Allmotor
    Allmotor
    57 thru 62 Corvettes used a spacer behind the balancer, it was the same thickness as the front motor mount which bolted between the water pump and block. The spacer was 1/8 to 3/16 inches thick and was made to fit in the keyway so it wouldn't rotate.
  15. ChucksCrib
    ChucksCrib
    from Uranus
    Fixed.....thanks for everybody's insight
