SBC starter experts - Which post is Which?
Discussion in 'The Hokey Ass Message Board' started by Choptop, Apr 18, 2011.
  1. Choptop
    Choptop
    Which one of the little posts is "Coil" and which one is the "ignition" (starter switch?) They aint labeled.
    I know the top (big) one is "hot" from the battery.
  2. I think you will find the small post closest to the block is the one you use. That's the case with my starters. I would also suggest you wait for a more confident answer though.
    You can bench test it ... using a battery and booster cables, supply power to the unit then quickly cross the large post and the inner (right hand) post with a screwdriver. If it spins the starter, that it (just make sure you have a decent grasp of the starter, might be a bit of a jump when it spins).
    Ooops, just re-read your post .... I guess I am saying that the inner (right hand) small post is for ignition (as in triggering the starter with the ignition key).
    Jeeze, I think I have now officially confused myself now.
  3. racer32
    racer32
  4. Choptop
    Choptop
    the one I use for what?
  5. the inner terminal comes from the starter terminal on your ignition switch , it activates the starter
  6. BudJ63
    BudJ63
    from Florida
    From Chevelles.com
  7. Mutt
    Mutt
    Here...
    Mutt
  8. Choptop
    Choptop
    so it does indeed look like the right hand post is the "ignition" post.
    I did the bench test, hot to the top post and bridged to the right hand posts causes the throwout to engage, but the starter did not SPIN. Hmmmm.. perhaps a bad starter motor.
  9. squirrel
    what the hell kind of starter motor is that?
