sbc stumbles and belches
Discussion in 'The Hokey Ass Message Board' started by 33_chevy, May 31, 2010.
  1. 33_chevy
    33_chevy
    from TX
    So i have a 400 sbc with trick flow heads with a 274 comp cam and a unilite dizzy with mechanical advance,running 4x2 intake with 4 new 97's(not speedway)with progressive linkage,intake is wiaend staggerd.The car runs real good.The problem is when it's warm and i turn it off it stumbles and belches out the carbs.I checked the timing and at about 600 rpm i am about 8 degrees,i have moved the timing both ways and does nothing for it.I am also running a 1 wire alternator.Could i be getting feed back from this...
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Sounds like its to lean and high cly. pressure. Try a richer idel mixture.
  3. 53sled
    53sled
    from KCMO
    Backfires through the carbs or spits raw fuel out?
  4. Try lowering the idle speed and advancing inital timing a couple of degrees.
  5. screwtheman
    screwtheman
    It's not the alternator feedback/diode thing... when that's a problem it just doesn't turn off at all!
  6. Gunny
    Gunny
    give this a quick look..it might help ya out..
  7. 33_chevy
    33_chevy
    from TX
    thanks for all the info..
  8. sdluck
    sdluck
    Did you syncoronize [sp] the primary carbs?
  9. 33_chevy
    33_chevy
    from TX
    Yes i did..But i just now was thinking, it started doing this when i changed air breathers,could this be the culprit..I went to a different style of breathers..
  10. thanks gunny.:cool:
  11. SATANSSHO4
    SATANSSHO4
    when you say stumbles and belches do you mean when you shut down it runs on for a little then spits fuel out the carbs?
  12. 33_chevy
    33_chevy
    from TX
  13. SATANSSHO4
    SATANSSHO4
    ok i just had this problem .it was before i put a timing light on it .my timing was to retarded and cause this .i advanced my initial timing to 18 your cam wont need this much at idle but more than 8. whats your total timing at 3000 rpm should be 36 give or take a degree or two, at 8 degrees yor distibutor is adding 28?
  14. Bigchuck
    Bigchuck
    from Austin, TX
    Stumbles and belches? I'm sure quite a few HAMB members can relate to that. Seroiusly though, try a little more initial advance- 12 degrees or so, richening up the idle mix, and closing the throttle plates a little. Use a vacuum gauge connected to constant maniflold vacuum and set idle mix screws for highest vacuum. That, and more initial timing will let you have the correct idle speed and allow you to close the throttle plates via the idle speed screws. Having the throttle plates too far open at idle can make it want to run on.
  15. PackRatWrecker
    PackRatWrecker
    from Kansas
    Stumbles & belches?
    You running it on alcohol?
    ...Oh Wait, that's me.
