Hot Rods SBC/T5 Problems, any suggestions
Discussion in 'The Hokey Ass Message Board' started by Christopher26, Jan 1, 2019.
  1. Nostrebor
    Nostrebor
    This is my setup, and it did exactly what I described above on the first swing. I loosened the bolts and slid it back, and dropped in some 1/8" plastic shims I have from work, and then snugged it back down. It was enough to make everything work. Now I just have to knock it back apart and find the tight spot. I'm guessing it's at the tip of the input. This process took about 10 minutes to check.
    Every time we mix and match a setup like thus it takes some trial and error to get there, but you can do it. 20190223_163442.jpeg
    Sent from my SM-G930V using The H.A.M.B. mobile app
  2. Christopher26
    Christopher26
    Ok great, is it the same parts as well (ford t5, abc?) I’ll be heading to harbor freight in the afternoon, thanks again for the pics
  3. Mr48chev
  4. Christopher26
    Christopher26
  5. Nostrebor
    Nostrebor
    I have a Davis Speed spacer on my current build. It stll needs tweaked a bit to work.
    The setup pictured is a NWC T-5 from an S10, a Doug Nash 4+3 bell from a Corvette, a Camaro flywheel and pressure plate, a clutch disk for a T-5 flathead conversion, and the Davis Speed spacer. I'm running this bell because the fork is at a more downward angle than typical, which works better in my car. Otherwise this is a pretty typical SBC T5 setup.
  6. bobss396
    bobss396
    That spacer is the missing piece to the puzzle...
  7. Share parts numbers with us please - I got an OT '68 Chevy, 327 with a 3 on the tree that I thought about putting a T-5 in - It has 3:73 rear & I thought a T-5 would be great! When you changed bell housing did you have to install a cross member to support the trans? - My ol' girl has mounts on the bell housing & I thought yours would too - thanks for a good read!!!! (yeah, it's still snowing in "good ol' w.va. usa")
  8. Randy Caudell
    Randy Caudell
    Don't have the book in front of me at present, but the JTR guys who do the S10/V8 conversions said something about cutting 1/4 inch off the front side of the clutch disc. Anyone here got the book handy to look that up? Mine is in the shop.
