SBC temp question. head vs. intake
Discussion in 'The Hokey Ass Message Board' started by 50mercfan, Oct 15, 2008.
  1. 355 ci. i have the gauge in the car (aftermarket gauge trio) connected to the head. it is showing 220 degrees. i installed another one in the intake it shows 195 degrees. these temps are at the same time while engine is idling. which one do i beleive? dosen't show any signs of overheating.
  2. pan-dragger
    pan-dragger
    i would think the head would be more accurate.
  3. da34guy
    da34guy
    The head will always read hotter than the intake.
    A SBC loves a little heat I.E.---200-220 degrees in the head
  4. olscrounger
    olscrounger
    I think the intake is the most realistic reading--as others have said, there is a 30 degree difference in most cases--also some gauges are very inaccurate-can correct witha resistor if gauge is electric-I think the ones in the head may? pick up some residual heat from the proximity to the exhaust
  5. SASROD
    SASROD
    Have you tried switching the guages to see if its really that much different between head and intake?
  6. no, i haven't. will try it. anybody else have an opinion?
  7. Deuce Roadster
    Deuce Roadster
    I have had sending units in both the heads and the intake. All three were wired to a rotary switch so I could check each one ... :) After the SBC had warmed up to operating temperature ... The intake sending unit always read 20 or so degrees cooler. :D
    One of the heads always read about 10 degrees warmer than the other head but I forget which one ran the coolest and which one was the warmest. I believe the right side head ran the warmest but I am not positive. :eek:
  8. bustingear
    bustingear
    Opinions are like ***holes...everyone has one:)
