Sbc timing advance problems
Discussion in 'The Hokey Ass Message Board' started by ironhill, Mar 19, 2013.
  1. ottoman
    ottoman
    from Wisconsin
    Like I posted.. if it runs it cant be 180 off.. geez
  2. swade41
    swade41
    from Buffalo,NY
    I would still mark the balancer, that timing tape has a tendency to come unstuck.
  3. No kidding ?
  4. mashed
    mashed
    from 4077th
    Ive used the BPB method (buddy power-braking) while I advance the timing 'til pinging many times.
    And if it starts cranking hard, back off a few degrees also.
    Haven't used a timing light since 1983. Eff-um.
  5. Jokester
    Jokester
    This is the correct way to do it. I recently lost a balancer (had to change the crank). I had 6 use ones stacked up on the bench with the keyways aligned. One was like what the OP had. The rest of them varied by almost 2 inches. I picked the best looking one and used the positive stop method to find zero. It is nearly 5/8" away from the original zero.
    If you don't use this method, you will never know what your timing really is.
    my 2 ¢
    .bjb
  6. oj
    oj
    ***uming you are looking at #1 cyl, then neither lifter should be down. both intake and exhaust lifters should up slightly up at TDC, the intake will be falling and exhaiust is rising.
  7. You are describing TDC on the overlap,
    Not TDC related to spark timing at the top of compression stroke where both valves are closed
  8. oj
    oj
    Yup, you're right, zero-crossover, thats where i check tdc and forgot there are two tdcs'. Just old habit and never thought about it.
