Technical Sbc to flathead trans adapter clutch
Discussion in 'Traditional Hot Rods' started by The Chevy Pope, Oct 4, 2023.
  1. Looking at speedways adapter kit and it says to use a 49-53 merc b & b pressure plate with a 10" flathead Ford clutch disc. After not finding much when googling for the recommended pressure plate I got curious. Why couldn't I just drill and tap the flywheel to use a regular flathead Ford pressure plate? Be more work but they're all over the Internet for sale
  2. tubman
    tubman
    The splines on the transmission input shaft are different. 1 3/8"-10 on the '48 and earlier transmission; 1"-10 on later disc.
    Don't quote me on the spline count.
    The Chevy Pope likes this.
  3. Yeah that's why they said use the Ford disc with the merc pressure plate. Just wondering if I can just redrill flywheel and use a complete early Ford clutch
  4. tubman
    tubman
    It could probably be done. Like everything else, it's cheaper and usually better if you can use a proper combination of stock parts. If the Merc pressure plates become unavailable, you may have to resort to machining and determining compatible components. Redrilling a flywheel at home on your drill press is not recommended.
  5. Nailhead Jason
    Nailhead Jason
    you can totally do that, redrill the flywheel that is. The reason to use the 49 to 53 merc pressure plate, is because it bolts directly on to the Chevy flywheel, since they have the same bolt pattern. That being said, as long as the pressure plate clears the adapter you can use any pressure plate that clears. You would need to take the flywheel and pressure plate to a machine shop to have the pattern drilled for that pressure plate. I've had old aftermarket race flywheels that had both patterns drilled from the factory that way.
  6. Dan Hay
    Dan Hay
    I have used the Merc pressure plate now twice because it bolts up. Machine shops around here take ages to do anything, including something as simple as drilling a flywheel. Last time I called Wilcap directly and they sent me one.
  7. nobby
    nobby
    i think it is because
    maybe the flathead transmission to small block chevy adaptor can ONLY use the smaller chevrolet manual flywheel
    168 tooth large 11''
    153 tooth flywheel small upto 10,5'' ?
    ergo you can only run a 10 inch max friction disc on a 37 up flathead transmission
    as the 11'' pressure plate hits the adaptor
    so
    you have to run the small chevy flywheel
    these are drilled 6 holes 60 degrees apart
    the 8ba mercury pressure plate SHARES THESE DRILLINGs - bolts straight on
    unlike the ford pressure plates and flywheels which have 3 close paired drillings!!
    YOU NEED to use a flat head pressure plate as the distance of the throw out bearing to pressure plate contact surface point remains stock flathead - and not for example a later style pressure plate that is multi fingered
    so 2
    its only the 10 inch friction disc with the spline count of the flathead input shaft
    that will fit the gearbox
    its only the flathead mercury 10 inch pressure plate that fits the small cevy flywheel
    its only the 10.5'' 153 tooth flywheel that fits the adapptor
    something like that
    TAKE HEED
    there is a 9.5'' clutch set that fits a mercury flywheel and they might be close.
    so dont buy the wrong one.
    and no a later 11'' 60 on 6 borg and beck style pressure plate will not fit as the rivet heads on the flat springs will touch the inside edge of either a half bell or a 59a - i.e. you wont be able to bolt on a half bell to an 8ba as there will be 5-6mm 1/4'' in the way = impossible.
    the 10 inch brings the rivets inboard 1/2'' and it goes in
    thats IF you want to keep the cross shaft and stock clutch pedal
    -typically just bough an 8ba with a t5 from a running car - 41 frd thinking it had a stock cross shafted clutch and its the later chevy fork style with an hydraulic slave, so now have to completely re-do both the brake and clutch pedals to get the clutch master in - as its rhd!!!
    pah!!
  8. Mine uses the 168 tooth FW
    Had a merc PP and correct gm flywheel.
    I pulled it out of a 63 c10 with a 230
    Im using the old style 3 bolt starter.
  9. nobby
    nobby
    does the clutch function
    i mean the transmissions cross shaft and double finger- acting upon the stock flathead throw out bearing and the distance between it and the contact face of the pressure plate
    do the two fingers from the cross shaft track a chord in a straight lineright to left
    as it looks like your cross shaft take off for the clutch pedal is too mar forwards - anti clockwise and not projecting up and back a smidgers
  10. I’m just putting this together.
    Going by the info at Speedway and here.
    https://content.speedwaymotors.com/Digital***ets/***ets/testing/7200392_INS_2021_1.pdf
    Using the merc clutch, PP and TO the set up should work just fine
  11. I have the starter and throw out bearing. Kit calls for the larger flywheel and all I have is a small one from a 57 Chevy 283. So I'll need to buy a flywheel (not a big deal). My issue is not finding anyone selling one new or reman. And can get the Ford equivalent new and reman. 10" clutch is to clear adapter and they specify the merc pp because of the bolt pattern. If they're the same height I honestly would prefer the redrill path as replacements would be easier
  12. Those B&B plates are not near as easy to find as the other style
  13. hotrodA
    hotrodA
    The CORRECT Borg and Beck 9 spring pressure plate for this hookup is Model 1310,
    49-50 and early 51 Mercury. Disc is standard Ford 10” with 1-3/8” 10 spline hub.
    Other B&B’s may bolt on and work, but this is the expert’s choice. Not me, Fort Wayne Clutch.
    Talk to Lou!
    The cores are hard to find. If Ft Wayne has them, the core charge is $90!
    If you have a clutch rebuilder close by you might get lucky and save some bucks.
    You also need a new pilot bearing from Speedway or WILCAP to mate the Ford input shaft to the Chev crank.
  14. I'll call tomorrow.
  15. hotrodA
    hotrodA
  16. Nailhead Jason
    Nailhead Jason
    FT Wayne clutch is the way to go. You used to be able to get the Merc pressure plates from Wilcap a few years ago. I've bought several from them over the years, but I've heard that they have sold to another company and they don't want to sell you just a pressure plate anymore, they want to sell you a whole kit. Not sure if its true but that's what I heard.
    Dan Hay likes this.
  17. will sigmund
    will sigmund
    from michigan
    hello, please help me here, do you use the 168 tooth fly wheel or the 153 fly wheel? i'm doing this conversion right now and i keep getting conflicting opinions on which fly wheel to use, thanks you ,Will.
    Desoto291Hemi and gary macdonald like this.
  18. will sigmund
    will sigmund
    from michigan
    hi Jason, you happen to know what fly wheel to use would you? a 168 tooth or a 153 tooth chevy fly wheel? thats my only hold back to getting this thing in the car !!!!lol
  19. will sigmund
    will sigmund
    from michigan
    Hi Athony, can you tell me what tooth fly wheel you used by chance? thanks, Will.
  20. squirrel
    Might help to know exactly what other parts you have, eh? There are a few different things discussed in this thread.
    What adapter do you have? what transmission? what clutch are you planning to use?
    The 3 bolt starter that they mention only works with the 168 tooth flywheel, if that's any help.
    Desoto291Hemi and anthony myrick like this.
  21. 168
  22. Dan Hay
    Dan Hay
    I have a part number for the right flywheel for a two-piece rear main but he has a one piece rear main small block. I’m finding 1 piece rear main 168 tooth but not much information on the bolt circle pattern for the clutch.
    I guess we also need to know what clutch you are using. Borg and Beck Mercury pressure plate 49-51 will bolt up to the flywheel below.
    for reference, here’s the flywheel I used for a two piece rear main.
    https://www.jegs.com/i/JEGS+Performance+Products/555/601205/10002/-1
  23. RICH B
    RICH B
    These kinda things.
    51 mercules and anthony myrick like this.
  24. will sigmund
    will sigmund
    from michigan
    hi dan i was going to use the '49 to '50 merc pressure plate and the disc that goes with it. if i have to i'll have the flywheel drilled and tapped because i know they are different bolt pattern to the crank.
    Dan Hay likes this.
  25. will sigmund
    will sigmund
    from michigan
    and the 1990 engine is externally ballanced.
    Dan Hay likes this.
  26. hotrodA
    hotrodA
  27. Nailhead Jason
    Nailhead Jason
    168 tooth is the one to use. If you have any questions on doing this just PM Me, ill send you my cell number and you can call or text me.
    51 mercules and teach'm like this.
  28. will sigmund
    will sigmund
    from michigan
    hi Jason that would be great, i would like to call, thanks
