Technical SBC valve seals
Discussion in 'The Hokey Ass Message Board' started by tin_indians, Feb 3, 2019.
  1. tin_indians
    tin_indians
    Admitting right up front I've never replaced valve seals before. With that out of the way, The seals I'm doing are off an '86 305 chev. The seals coming off are black and my replacements are white. There is a length difference. Is it important that the seal reaches deep enough to reach the "step" on the valve guide? Both seals in the pics are resting on top of the valve guide.
    Thanks guys.
    seal 001_compressed (1).JPG seal 004_compressed.JPG seal 008_compressed.JPG seal 009_compressed.JPG
  2. saltflats
    saltflats
    from Missouri
    Being just an umbrella seal, that will work fine.
  3. jimmy six
    jimmy six
    They need to be pretty tight on the guide boss. Some have "ridge" on the inside that makes them go on ez but hard to pull off. Over time the originals got crispy and cracked. Hope these are better.
  4. tin_indians
    tin_indians
    Well then that sux. While the new white nylon seals are quite snug on the valve stem, they're absolutely sloppy on the boss. Maybe .025" wiggle. They will ride up and down with the valve. To me, these aren't any good...
  5. 2OLD2FAST
    2OLD2FAST
    from illinois
    While yours aren't " positive" seals , they'll shed excess oil away from the guide as designed... Are you guides tight ? , Don't expect seals to make up for sloppy guides ....
    saltflats likes this.
  6. saltflats
    saltflats
    from Missouri
    That is what a umbrella seal does.
    Now a PC seal is a different story.
  7. saltflats
    saltflats
    from Missouri
    You were quicker to the draw.
  8. tin_indians
    tin_indians
    I don't have a magnetic dial indicator to measure side play. The stem itself has a shiney section where it rides up and down in the guide, but theres no "notch" on the stem that you can feel with your finger nail. I'd say they are ok.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    The majority of the wear with valve guides is the iron guide , not so much the valve stem ,( hardened )
  10. tin_indians
    tin_indians
    Oh, ok. Well, like I said, I have no dial indicator. This is really just a "buy a used engine, clean it and re-gasket/seal it, replace the cam chain and gears, valve seals, rebuild the carb, new tune-up parts and throw it in my '54.
    I bought and drove the truck home, so it was running ok at the time. It was just a leaking mess.
  11. 2OLD2FAST
    2OLD2FAST
    from illinois
    If you have the heads off , put the valve in about 3/8" from closed and single side to side , if they're slopping around you could get the guides knurled but then you'd have to grind them too. Dial indicator doesn't tell you much , not accurate enough to be worthwhile ....
  12. buffaloracer
    buffaloracer
    from kansas
    I've never had much luck knurling guides and feel like it is a waste of time.
    Maybe others have had better luck.
    Pete
  13. 2OLD2FAST
    2OLD2FAST
    from illinois
    I've had them last 20k miles give or take , that's about it
  14. saltflats
    saltflats
    from Missouri
    Pull the valve out of the seat a little and give it a wiggle back and forth in all directions, if you think you can measure the movement with a tape measure then the guides will need help.
  15. tin_indians
    tin_indians
    HAHAHA!!! Jesus...a tape measure? There isn't that much slop. I thought someone was gonna say so many thousandths of a inch. Hehehe,...that was a good one.
  16. tin_indians
    tin_indians
    One done, re***embled with federal mogul pre-***embly lube. Went with the umbrella seals. Funny though, when I pulled the valves there was no evidence of the upper rubber o-rings anywhere.
    Just a final cleaning of the intake ports surface for a good gasket seal.
  17. 41rodderz
    41rodderz
    from Oregon
    I had valve guides knurled on a V 8 Pontiac. Worked for me .
  18. jimmy six
    jimmy six
    There was an extra notch or ring cut in the valve stem under the keepers where the o-ring was placed along with the umbrellas over the tops of the springs was good enough for 100,000's of stock Chevrolets...
  19. sunbeam
    sunbeam
    In the mid 60s I worked in a machine shop doing mostly head work. Oldsmobile v8 heads were knurled the big dealer in town would bring in several sets every week to get guides under warranty.
  20. Engine man
    Engine man
    from Wisconsin
    That's what you want. If the seal moves on the shaft, the hole eventually wears out. For the seal to work like an umbrella, it doesn't have to fit tight on the guide. All it needs to do is direct the oil around the guide.
    tin_indians and egads like this.
  21. tin_indians
    tin_indians
    Exactly Jimmy, I have those two notch valves. I made sure the seal kit I bought had those little o-rings for that extra notch. I installed them with a little oil on them so they slipped on without rolling over.
