Technical SBC valve stem seals
Discussion in 'The Hokey Ass Message Board' started by 61Cruiser, Mar 8, 2025.
  1. 61Cruiser
    61Cruiser
    Hi Everyone, this is the first time I’ve posted a technical question on the H.A.M.B. so my apologies if I’m not as clear as possible. Here goes. I’ve got a 1961 Chev Belair with a 283 with Canadian cylinder heads. The engine has had two overhauls in its life but I’m not sure if what work was done to the heads if any. The car started to foul a couple a plugs a while ago and puff a little bit of blueish smoke on start up. I bought a 16 rubber umbrella seals and installed them with the heads still on the engine. I used one of those screw type spring compressor.That’s where I think I made an error. When I installed the seals, I pulled the springs off the valve over the original o ring and if it broke I didn’t replace it. Luckily the only ones that broke were on cylinders 3 and 7 on the intake valve. When I started the car the smoke was worse and I burnt nearly a quart of oil in a little under one hundred miles but I did manage to kill a lot of mosquitoes. I bought 16 valve stem o rings and installed them on all valve stems, but I put the o rings on and then very gently pushed the valve spring and the part the sits over the top of the spring (sorry, don’t know what it’s called) over the o ring after lubricating liberally with engine oil. Put it all back together and I still get smoke after decelerating but not as bad. Have I stuffed up the o rings? Or is there something else that causing the smoke. The heads may need new guides but I don’t drive it much and I installed the umbrellas and o rings to try and delay getting the heads overhauled. Could a leaking intake gasket also caused symptoms similar to failed valve stem o rings? I appreciate any advice that you could give me and will post updates if I get a solution. Many thanks in advance.
    Mark.
    (61Cruiser)
    tractorguy likes this.
  2. NoSurf
    NoSurf
  3. Kevin Ardinger
    Kevin Ardinger
    Those umbrella seals should have fixed your problem if it was valve stem related. You don’t need the O-ring seals if you’re using umbrella seals. You would need to make sure the umbrella seals are not getting damaged by the valve springs when the valve opens. Sounds like it’s burning oil for some other reason. Possibly the intake manifold is not sealing correctly to the head at the bottom. ****ing oil from the valley into the cylinder head. That’s what I would check next.
    61Cruiser likes this.
  4. garyf
    garyf
    It could be me but I find it hard to understand how you wrote you did this repair. Did you use the plastic sleeve thats sometimes supplied with the seals to get them over the valve stem keeper grooves that prevents destroying a new seal ? Are the oil returns in the head clogged ? Also, if a lot of oil has collected in the mufflers, it wont burn out easily.
    61Cruiser, tractorguy and ClayMart like this.
  5. Oneball
    Oneball
    If the guides are bad, changing seals or o rings won’t really help.
    61Cruiser, jimmy six and 2OLD2FAST like this.
  6. Pav8427
    Pav8427
    Oring seals go on the valve stem after you compress valve spring/retainer.
    IE. Compress spring/retainer-install over valve-install orings-install locks-release spring pressure.
    If the umbrella seals are not quite the right ones at full valve lift they can act like an oil pump and actually push oil down the guides into chambers.
    Make sure they dont fit tight over the valve guide boss/casting.
    And just for curiosity, never heard any Chevy heads refered to as Canadian heads.
    Is that a thing?
    61Cruiser and tractorguy like this.
  7. squirrel
    this.
    The spring retainer (the big round part with the tapered hole in it) has to come up from the bottom to "cover" the O ring, after you put the O ring in it's groove.
    Just for fun, have you done a compression test on the engine?
  8. Onemansjunk
    Onemansjunk
    from Modesto,CA
    Valve Recession, being how old these heads are, pops into my head. Valve guides for sure.
  9. sdluck
    sdluck
    Leaking Intake gaskets will cause this and very common.
  10. 61Cruiser likes this.
  11. 61Cruiser
    61Cruiser
    Hi Kev, thanks for the info. I always thought that the umbrella seals made the o rings unnecessary but that apparently only applies to the positive seal umbrella type. I’m using the soft rubber, “ford” style so still need o rings. So I’ve been informed.
  12. 61Cruiser
    61Cruiser
    Hi “garyf”, I’m only using the rubber “ford” type umbrella seals so did not have the little plastic doohickey that comes the positive GM type seal. I checked the drain back has as you suggested as they seem clean. Thanks for your reply. Every bit of info is useful to me. Cheers.
  13. 61Cruiser
    61Cruiser
    Hi “Oneball”, I’m really hoping I can put off getting the guides done. It really wasn’t smoking that much before I started all this, now wishing I hadn’t.
    Oneball likes this.
  14. 61Cruiser
    61Cruiser
    Hi “Pav8427”, thanks for your reply. I have gone back into the garage this morning and pulled the valve springs again and have followed the instructions that you and @squirrel suggested. I’ve done 4 out out 8 cylinders( exhaust and inlets valves) and on two of the inlets I found that I had pushed the o ring out of the groove when I previously installed. After following your instructions I’m confident that the o rings are in the groove. I’m going to finish up the rest and I’ll post something here on the results. Thanks to you both, and really to everyone for their responses. The H.A.M.B. is brilliant for getting information on these old cars and engines. Also in answer to your question on Canadian cyl heads. This car is an Australian “***embled” Belair. That means it was “built” as a right hand drive car in Canada as kit (CKD= Completely Knocked Down) and shipped to Australia and the “***embled” here by GMH (Holden, a GM brand here in Australia) The cyl heads have cast into them CANADA and have a casting number that I have never been able to get solid info on. I’ve been told they are truck heads with 60cc chambers and small valves. I’ve attached a couple of photos.
    Oneball likes this.
  15. 61Cruiser
    61Cruiser
    Hi “sdluck” thanks for your reply. If this doesn’t work, the intake gaskets is my next step. Cheers and thanks again.
  16. 61Cruiser
    61Cruiser
    Hi “Algoma56” thanks for the info. I checked out the thread at it confirm was what @Pav8427 and @squirrel posted. It confirms that my first installation process for the o rings was wrong. As my earlier post shows, I may now have the problem solved. When I finish up the last 4 cylinders I update this thread. Thanks heaps again everyone. Cheers.
    lothiandon1940 likes this.
  17. Kerrynzl
    Kerrynzl
    Yes ,
    Especially in NZ where our Chevys and Pontiacs had 283 engines with different casting numbers.
    They weren''t special
    All these engines had blank [non-script rocker covers]
    The whole thing was a tax loophole in the 60's with NZ and Canada both being British Commonwealth countries
    Here is a 283 engine I pulled from a Canadian ***embled RHD '66 Impala
    It had 1816887 "Canada" on the castings
    Deuces likes this.
  18. 61Cruiser
    61Cruiser
    Hi “Kerrinzl, has that engine got staggered valve cover bolts? That’s also something unusual about these heads. I’ve been told that long after GM started using parallel bolts, these heads still had staggered. I managed to pick up a pair of “Chevrolet” raised script staggered bolt covers for my car, which I had chrome plated of course, ‘cause chrome will get you home!
    Cheers
    SS327 likes this.
  19. Kerrynzl
    Kerrynzl
    That engine shown had straight bolt pattern on the rocker covers
    Staggered bolt heads were 1955- 1958 [some say mid 1959]
    With your 1961 Chevy, if it is factory RHD it would be Canadian ***embled [or Aussie ***embled from a CKD out of Canada] so it could be possible to have oldish castings.
    Check the casting dates on both heads ,AND the block and it will give you a clue.
  20. Pav8427
    Pav8427
    Learn something new every day. How about some pics from different angles. What ever you can get.
    Maybe the shapes casted into the ends of the heads will give more clues
  21. garyf
    garyf
    The plastic "doohickey" would be for all types of valve seals for all makes of cars. To prevent the seal being destroyed being pushed over the valve keeper groves. A piece of wax paper wrapped around that area could be a subs***ute for the doohickey..
  22. 61Cruiser
    61Cruiser
    Hi “Pav8427”, I’ll get some pics uploaded when I get back to the garage. Next couple of days will be driving my father in law to and from hospital so he can get a pacemaker installed. The casting shape on the front of the heads, from what I’ve been told, is called a “single hump” but I don’t think they are anything racy. Like I said earlier, small combustion chamber, smallish valves.
    Cheers,
    Mark.
  23. 61Cruiser
    61Cruiser
    I didn’t get any doohickey (luv that word now!) when I bought the umbrellas. I was very careful when I installed them though. Lots of motor oil for lubricant and slowly worked them over the keeper grooves and the o ring grooves.
    Cheers,
    Mark.
  24. Kerrynzl
    Kerrynzl
    Here ya go
    Canadian 265-283 Truck heads with staggered rocker covers [these were on a 1957 283 but had 265 small ports and the matching small port 2v intake]
    You can just see the word Canada on this photo
    The casting # seen is 837065 with the letters "LO" in it
    So I ***ume it was 3837065 Low Compression [for a truck engine]
    You can clearly see the staggered bolt pattern here
    This is the end casting
    Unfortunately I don't have any better photos of the casting numbers
  25. 61Cruiser
    61Cruiser
    Hi “squirrel”, sorry I haven’t responded sooner. Thanks to your and @Pav8427 replies I’ve rechecked 4 out of 8 cyl and found 2 inlet valve o rings has slipped out of the groove due to my incorrect installation. I will be checking the rest of the cyl shortly. I haven’t done a compression test yet as I don’t have a tester, but I am going to borrow one on the weekend. I’m hoping that when I checked the rest of the cylinders I’ll find more o rings out of place and I should be able to fix this problem. I’ll definitely let everyone know how this turns out. Thanks again.
    Cheers
    Mark.
    TagMan and Chucky like this.
  26. 61Cruiser
    61Cruiser
    Well Hello to all you Hambers, a big thank you to all who replied with suggestions and tips on my question. I finished of re-installing the valve stem o rings in the correct manner this morning. Took the old beast for a test drive and even after a big decent down a long hill near me, when I got on the throttle at the bottom, no smoke. I’m so happy. I’ll monitor the oil consumption and plugs to see if that improves as well, but I’m hopeful it will all be an improvement of the previous situation. Cheers and thanks again to you all.
    Hollywood-East, SS327, Chucky and 5 others like this.
  27. 61Cruiser
    61Cruiser
    Well Hello to everyone again, turns out I might have had valve stem seal problems, I might have worn valve guides, but when I unhooked the pcv to checked to see if it was faulty, cause I was still getting smoke on the overrun, she was chuffing smoke out the breather like a big ol’ steam train. I think the pcv has been masking the blow by issue and not until I started getting oiled up plugs did I realise how bad she is. The engine still run ok but it must be really worn out. So now I ponder what to do. Money is a problem cause I’m retired and now all this business with stock market is causing my superannuation ( like your American 401 k I think) to be under a threat. I guess I just sit and look at the old girl a while and hopefully come up with a plan. Just wanted to thank you all for your suggestions and ideas and let you know what the outcome was.
    Cheers, Mark.
    lothiandon1940, 427 sleeper and SS327 like this.
  28. Hollywood-East
    Hollywood-East
    Sounding like Your rings have seen better day's unfortunately...
    The compression test squirrel mentioned, Will tell You everything you don't wanna know...
    Blow by is created by compression blowing by the rings...
    Back in the day Used car lots would take the aircleaner off, An trickle comet cleaner down the carb. (Running of course) to scuff the cylinders... An No I'm not recommending this, Just old time car lot trickery..
  29. 61Cruiser
    61Cruiser
    I did a compression test, but results were pointless as the amount of oil in each cylinder gave me false readings of 150psi. But, when compressed air was put into the cylinders the rings could not hold it. My compressor was set low but it would still kick in repeatedly on nearly all cylinders. Talking to a mechanic I know, it seems that this is good sign she is in need of an overhaul. I’ve got two good kidneys, anyone need one?
