Hot Rods SBC Water Pump Help
Discussion in 'The Hokey Ass Message Board' started by Wulf77, May 21, 2016.
  1. Wulf77
    Wulf77
    Hi guys, I am new here and I have a problem. I am searching for a SBC water pump that is shorter than the normal short water pump. The clearance between my low profile electric fan is too small for the traditional SBC short water pump. I need like an inch more clearance. Any ideas or thoughts?
  2. dentisaurus
    dentisaurus
    from Boston
    could you use zips riser and ditch the electric fan?
  3. mcyunger
    mcyunger
    move the radiator. this is why the mock up stage is so important. we have been through this problem as many hambers have too.
  4. DDDenny
    I know of no shorter pump than the oem "short" one, this kind of problem usually arises from placing the engine too far forward to gain clearance at the firewall when using larger diameter distributors such as HEI style.
  5. Wulf77
    Wulf77
    My engine is so close to the firewall I cannot fit a HEI, unfortunately. Radiator cannot go any further forward. I pulled out the engine and trans in this car. I replaced the tired 305 with a nicely built 350. It originally had a flex fan on. I decided to opt for an electric and I thought I would have enough clearance. I was wrong.
  6. it sounds like there is some clearance...or does it interfere? post a picture
    Spal has some very low profile fans
  7. lurker mick
    lurker mick
    You may have to go back to a mechanical fan ( not a bad thing). Get a good 18" 6 blade steel fan instead of the flex fan.
    Mick
    Nailhead Jason and Just Gary like this.
  8. tfeverfred
    tfeverfred
    Go back with the mechanical fan.
    Just Gary likes this.
  9. Just Gary
    Just Gary
    Mechanical fan.
    Get a big heavy duty steel one if there's space or a thin one if there isn't.
    Leave the electric fans for the guys with transverse engines...
    BTW, welcome to the HAMB.
  10. Wulf77
    Wulf77
    I just took it out and put in a mechanical fan. I am not wasting any more time on that. I am anxious to get back on the road. I still have to hook up exhaust, fuel, power and cooling.
  11. DDDenny
    A well designed fan shroud with the fan situated half way out of the opening should be adequate ***umming timing settings are correct.
    Some thermostat juggling may also be needed.
  12. nunattax
    nunattax
    I fitted a spal fan in my 38 chevy pu.kept the fan high up in the rad so the motor didn't interfere with the pulley on the waterpump.I also tilted the rad slightly,moved the bottom of it forward a little.this involve making new brackets for the rad.rad is alloy,thicker than stock.engine is sbc
  13. Jalopy Joker
    Jalopy Joker
    some pics would really help us to help you
  14. c-10 simplex
    c-10 simplex
    It may not be practical now, but as a side note and for the future, switching to 4.3 v-6 will get you 4.5" more inches of clearance.
  15. 2OLD2FAST
    2OLD2FAST
    from illinois
    Yep , nothing says "streetrod" like a 4.3 v-6...:rolleyes:
    dave
    31Vicky with a hemi likes this.
  16. Not now. not ever.
  17. Man dude, youll ask for pics of any damn thing.
  18. nunattax
    nunattax
    post the pics
  19. Good choice,
    but loose the old flex fan blade.
