Technical SBC water pump riser hose recommendation
Discussion in 'The Hokey Ass Message Board' started by ric, Feb 2, 2026 at 10:54 AM.
  1. ric
    ric
    I am installing a Vintage Air SBC water pump riser and looking for a lower hose recommendation. It uses the '63-'75 250 Chevy water pump, my car is a '32 with a '32 style Walker radiator. Any suggestions that will keep me from digging thru my local Napa store's hose collection ?
  2. Johnny Gee
    Johnny Gee
    from Downey, Ca
  3. RockyMtnWay
    RockyMtnWay
    Visual proof that directions work. :cool::cool:
    On one of my posts I also list a part number for the thermostat housing as well, as I find it the best angle for the upper hoses I use on these builds. ;);)
    Especially if you are using a bigger air cleaner or multicarb setups.
    427 sleeper and catdad49 like this.
  4. Happydaze
    Happydaze
    Is the Vintage Air riser as the Zipps riser? Might it be that VA took over Zipps offering? Just curious.
    Chris
  5. Mr48chev
  6. 19Eddy30
    19Eddy30
    from VA
    @Happydaze
    vintage air as of last week has there brand in stock , might be a Zipps ??
    I do not think John of Zipps is still with us ..
    mad mikey likes this.
  7. ric
    ric
    This great, thanks guys. The Vintage Air riser came with zero directions other than to say what water pump to use. I have no idea if it is the same as the Zipps riser, never really had a good look at one to compare. My existing upper hose and t-stat housing worked fine. The HAMB comes thru again !!!
    Driver50x likes this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The portion of instructions I posted was from Zip. Just looked at Vintage Air and well…https://vintageair.com/content/19212-VCB.pdf
    19Eddy30 likes this.
  9. ric
    ric
    I guess Zipp really was the first one of these, correct ? I had to modify my riser as I'm running a generator and no ac. But was able to use all my existing pulleys as well. IMG_2619.JPG IMG_2620.JPG
    427 sleeper and Johnny Gee like this.
  10. Johnny Gee
    Johnny Gee
    from Downey, Ca
    @ric your photo appears to not show a bleeder valve or bleeder hole? Zip’s did come with this feature. IMG_5238.jpeg IMG_5239.jpeg
  11. ric
    ric
    Hmmm, right you are. Had not considered that. I think at this point I will go ahead and install the lower hose and see if the cooling system will burp out any trapped air. If not then back to the drawing board, drill and tap for a bleeder valve. Thanks for pointing that out !
    pprather likes this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I just edited (added another pic) to that reply.
  13. ric
    ric
    Thanks for all the info, appreciate it. I'll see how it goes and report back.
  14. 19Eddy30
    19Eddy30
    from VA
    I have 2 Zipp's
    The older one did not have bleeder ,
    Later ones did my zipps came straight from John ,
  15. RockyMtnWay
    RockyMtnWay
    FWIW…I see a smaller diameter crank pulley in your pic….
    You’ll hear some varying opinions on this, but I’d suggest you heed the directions on pulley sizes too. Under or over driving the 6 cyl pump will likely affect your cooling efficiency.
    In my experience, the standard 1:1 ratio pulleys (that are easier to find) were not as effective at lower rpm’s. Once I switch to the sizes recommended, the pump/cooling worked much better.;);)
  16. RockyMtnWay
    RockyMtnWay
    You’re also going to get some feedback on your pumps impeller design.
    I don’t think you can buy the disc to rivet on anymore, so getting the “hi-performance” pump with the “correct” impeller is important.
    Like maybe a FlowKooler 1777CW.
    Cheers.
  17. Just Gary
    Just Gary
    Gates #20242 or 20225, depending on how close your water pump is to your radiator.
  18. ric
    ric
    Thanks for all the feedback.....lots to think about now !
  19. RICH B
    RICH B
    Chucky likes this.
  20. 19Eddy30
    19Eddy30
    from VA
    You can just tap , like #8 Machine screw
    or 1/8 for npt cap / plug , Just so air can escape, usually only takes 3/4 to 1 turn loose.
    Also nice to have Npt tap's even cheap
    H-F so when you have a Npt
    fitting ,plug that has 5 threads plus showing You can tap 1-2 turns deeper
    @ a time so all those threads are not showing for cleaner look , especially on a lot of China Npt that are not tap corect & only screw in 3 ish threads.
    Just Gary likes this.
  21. ric
    ric
    Thanks guys, more good info.
  22. patsurf
    patsurf
