Featured Hot Rods SBC water pump riser
Discussion in 'The Hokey Ass Message Board' started by eldridge, Aug 10, 2026.
  1. eldridge
    eldridge
    from Kentucky
    Afternoon
    I am needing an SBC water pump riser. It appears that Zip made them, and a company called Snow White. (No word on the seven dwarfs) Apparently the Zip product was bought by Vintage Air. Now Vintage Air says they are no longer available.
    Any ideas? I tried eBay.
    Thanks
    Kevin
  2. alchemy
    alchemy
    You aren’t the only one. Multiple threads recently about them.
    Johnny Gee and lothiandon1940 like this.
  3. Jmountainjr
    Jmountainjr
    Unfortunately Snow White stopped production a number of years ago. Their riser was based on an Opal water pump. It was a clean looking unit without additional accessory brackets. The early Zipp risers were also available without accessory brackets. Unfortunate that Vintage Air stopped production. So, today it's finding a used one or make one.
  4. lothiandon1940
    lothiandon1940
    Such an opportunity for someone.
  5. bchctybob
    bchctybob
    I can’t believe Speedway hasn’t grabbed the ball and run with it. Seems like they could name their price.
    lothiandon1940 and jimmy six like this.
  6. A Boner
    A Boner
    Good job…Vintage Air!
    pecker head and milwscruffy like this.
  7. eldridge
    eldridge
    from Kentucky
    I spoke to Speedway today and they just list it as discontinued.
  8. eldridge
    eldridge
    from Kentucky
    I called Vintage Air and also Pete & Jakes. Apparently Zip was making them for every retailer.
    lothiandon1940 likes this.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I have what I believe is one of the last units from Vintage Air. The back side of the riser does not have Zip casted on it nor the bleeder hole boss.
  10. eldridge
    eldridge
    from Kentucky
    Did I miss where you said what you wanted for it?
  11. HOTRODPRIMER
    HOTRODPRIMER
    The snow white water pump riser was designed for Fords, I haven't heard that the zips was purchased by Vintage Air but the owner of Zips I am told p***ed away and his family didn't want to take over the business.
    If I were a younger man I might try to negotiate with the family to purchase the patent.
    HRP
    bchctybob and A Boner like this.
  12. X-cpe
    X-cpe
    The fact that no one is tripping over themselves to produce one may be a silent comment on market size and ROI.
  13. patsurf
    patsurf
    this!
  14. RICH B
    RICH B
    Long time ago I read an article, where they mounted a fan hub of some sort above the water pump on a sbc and drove it off the outer groove of the water pump pulley.
    If I remember right it was a pretty clean set-up.
    I tried to find the article with no luck.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’d like to see that as well.
  16. Jmountainjr
    Jmountainjr
    Yes, one of Snow White's first products was a very short version of a Ford water pump. It was used by many racers and rodders alike. It was about two inches shorter than the Ford water pump and was aluminum that saved a bit over 13 pounds compared to the Ford cast iron pump. It also moved the lower hose to the opposite side so a Chevy radiator configuration could be used. They later came out with the aluminium SBC water pump riser that used the aluminium Opal water pump instead of a Chevy six cylinder pump like the Zipp riser.
  17. continentaljohn
    continentaljohn
    Does anyone have a picture of either setups. Just curious how they look front and back thanks
  18. HOTRODPRIMER
    HOTRODPRIMER
    This is the Zips riser for the sbc, it uses a 6 cylinder water pump & raises the water pump up 5" to center the fan on the radiator. HRP
  19. eldridge
    eldridge
    from Kentucky
    Do any of you guys know of one for sale?
  20. Jmountainjr
    Jmountainjr
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Inspiration…
    I’ll leave myself out because I’ve never TIG welded nor ever learned via any schooling on MIG welding.
    This would be such a simple sheet stock item to produce. Think sheet metal intake fabrication.
    bchctybob, 29EHV8, 69fury and 2 others like this.
  22. 19Eddy30
    19Eddy30
    from VA
    From here & there are few other way's to raises
  23. 29Sleeper
    29Sleeper
    from SoCal
    With laser scanning of an original and mail order printed sand cast molds someone could do a few and make some $$$. The advantage of this is you omit the time consuming pattern making that requires real skill.
    bchctybob likes this.
  24. wauto
    wauto
    There is a 32 coupe on the Ruth estate auction that uses some sort of elevated fan hub setup.
  25. continentaljohn
    continentaljohn
    Thank you for the pictures @HOTRODPRIMER @Jmountainjr and never use one or seen one around here.
    @19Eddy30 very interesting idea and more then one way to skin a cat. That looks very doable on a mill or with companies like send cut send
    RICH B, lothiandon1940 and bchctybob like this.
  26. eldridge
    eldridge
    from Kentucky
  27. 19Eddy30
    19Eddy30
    from VA
    No , Not my work / designs .
    The pictures I posted are from here that other have posted .
    The riser blocks is
    Simple made
    6 to 7 pieces per side .
    3 pice's of flat plate stock
    & 3 to 4 pieces of tube stock with 3/8's ID . Depends on the rise / offset.
    The plat is more complicated.
    But simple made with hand tools
    The thick pice look's to have been
    3/4 or so flat Steel plate ,
    I would use ABS type of plastic .
    Myself over years I have cut water pumps up made things work
    Some eye pleasing other just to make functional .
    continentaljohn likes this.
  28. 19Eddy30
    19Eddy30
    from VA
    Other will be interested in another thread about Zip ,riser
  29. Johnny Gee
    Johnny Gee
    from Downey, Ca
