Sbc water pump riser
Discussion in 'The Hokey Ass Message Board' started by terry48435, Mar 17, 2011.
  1. terry48435
    terry48435
    Is anyone on here using a Zip's water pump riser on their sbc? I need to know what I need for a lower hose for this setup. I am hoping there might be a part number for a hose or what I need to do to make one up. I have a Walker radiator with the lower outlet on the p***enger side. I've included some pics of the riser.Thanks for any info you can give me.
  2. bob giles
    bob giles
    I have one but not quite done yet. I resorted to stainless coragated (sp?) pipe with rubber sleeves in order to get tighter bends.
  3. roundvalley
    roundvalley
    I think DEUCE ROADSTER knows this set up.
  4. terry48435
    terry48435
    I talked to Dean Alexander at "The Hot Rod Garage", He used one in an article on building a fan shroud in the May issue of Street Rodder and he said a Dayco 72088 may work, that's what he used.
  5. wildearp
    wildearp
    from tucson, az
    I am running one on my Model A. I just go to the parts store and they let me go in the back and pick my hoses. I don't recall that this was a very difficult hose to find. What is your exact application? Be sure to drill holes in your thermostat flange to prevent steam/air pockets. This should be in the instructions.
  6. no55mad
    no55mad
    If you search hoses here, someone just gave a part # for this setup.
  7. terry48435
    terry48435
    My bad. I checked for threads on the subject and found all the info I needed. Hose numbers, pump number,bleeder number, belt sizes, what pulleys I need, etc.DEUCE ROADSTER had all the info. Thanks Guys.
  8. Dipper Jr
    Dipper Jr
    from Indiana
    I just finished mine. Take the dayco belt number and the GM bleeder valve number to your local NAPA. My guy crossed those to napa numbers and had the parts the same day!
  9. terry48435
    terry48435
    Will do. Thanx
  10. hotrod_32
    hotrod_32
    I ran the same set up before. I used a ribbed univeral hose on the bottom. Can find one at most parts stores. Was running the zip riser 6 cly. chevy water pump Walker Rad. 38k no problems.There was also a smaller hose that ran from my intake to the riser.Can't remember size,around 5/8"(heater hose) Ran cool all the time ! Great set up
  11. Deuce Roadster
    Deuce Roadster
    I use a Gates #20225 lower hose.
    The vent number is GM #10070107
    Zip's suggest using the pulley # 3995642 for the pump and # 385838 for the bottom pulley.
    I use a Chevy van thermostat housing ( 85 with a 305 ) ... :D
    It goes straight UP :D
  12. terry48435
    terry48435
    Thanx man, you're a life saver.
  13. Deuce Roadster
    Deuce Roadster
    :D
    Us 32 Ford guys have to stick together :eek:
