Hot Rods SBC water ZIPS pump "RISER" alternator mount ?
Discussion in 'The Hokey Ass Message Board' started by wheelguy, Sep 14, 2018.
  1. wheelguy
    wheelguy
    Hey guys, I have a CHEVY small block ZIPS water pump riser without the built in alternator mount.
    Anybody out there know of an ALTERNATOR MOUNT that works with this ?
    I CAN'T run a low mount alternator off of the front motor mount holes.
    I need to mount it high. I have heads with factory holes I can use (NEEDS TO BE DRIVER SIDE MOUNTED)
    If you know of a source, brand supplier or part number for a mount please POST or PM an answer.
    THANKS, Joe
  2. big duece
    big duece
    from kansas
    Is yours cast iron or aluminum? I just cut off the "ear" for the alternator on mine, but mine is cast iron. Too bad, we could have traded.
    26hotrod likes this.
  3. wheelguy
    wheelguy
    Mine is aluminum but it had the "ears" cut off of it also > that's the problem .
  4. big duece
    big duece
    from kansas
    If yours had been the cast iron one, you can have the mount i cut off. But, this one wont help you out. 20180914_185440.jpeg 20180914_185425.jpeg
    Sent from my SM-G900P using The H.A.M.B. mobile app
  5. big duece
    big duece
    from kansas
  6. wheelguy
    wheelguy
    It has to be unrelated to the water pump as the riser is thicker at the top drivers side water pump bolt. It would need to be all head connected bolts. I also don't want it any higher than necessary.
    THANKS, Joe
    Are you running an alternator????
  7. nwbhotrod
    nwbhotrod
    from wash state
    make one its not that hard
  8. big duece
    big duece
    from kansas
    Mine will be down low on drivers side.
  9. lumpy 63
    lumpy 63
    use a bracket for a 67-72 chevy pick up bolts to front of drivers side head although probably wont work with hood sides...
  10. big duece
    big duece
    from kansas
  11. lumpy 63
    lumpy 63
    Thats an exact copy of the 67-72 pick up bracket.. I have several in my shed:rolleyes:
    26hotrod and big duece like this.
  12. DDDenny
    I know you said you didn't want a low mount, but this is how I byp***ed the need to cut the ears off my alternator, a Ford Motorsports part, I was sure it would fit but then I pinched the rails 3/4" each.
  13. lumpy 63
    lumpy 63
    Lots of aluminum going on there Denny:D
    Montana1 likes this.
  14. wheelguy
    wheelguy
    DDDENNY < >Actually I do want a low mount but someone has "boogered" up my lower front mount hole (the one for an early small block motor mount) so bad I can't use it for a low mount alternator bracket.) Motor is in the car and I can't get a drill in there to drill out for a heli-coil. I wanted the alternator out of sight but now trying to find a "head" mount to place alternator up higher.
  15. DDDenny
    :cool:
  16. DDDenny
    :cool:
  17. oldolds
    oldolds
    Can you get a tap in your hole? Tap it one size bigger. 7/16? There should be enough to hold it.
  18. 26hotrod
    26hotrod
    from landis n c
    Ford alternator on a sbc?! A lot of people would argue with that but this is a hot rod...…..
  19. DDDenny
    Never tried to hide its pedigree (or lack of) but my car has a total of two Ford mfg. parts, the alternator and the nine inch rearend housing.
  20. X-cpe
    X-cpe
    Then put a stud in the hole.
    I made my alternator mounting bracket to pivot off the upper front hole. The adjustment slot uses the lower hole with a solid arm from the normal adjuster ear to the upper water pump bolt. This allows the alternator to slide up and down the side of the block as you adjust the belt. There is also a brace that goes back to the motor mount bolt on the block with a slotted arm to the back of the alternator to take some of the stress off the two front bolts. Sliding the alternator up and down the side of the block probably won't work with a hood.
    big duece likes this.
  21. sunbeam
    sunbeam
    ****** Makes a bracket for hedders that mounts off the front exhaust port
  22. HOTRODPRIMER
    HOTRODPRIMER
    Anyone use a zips riser and not using the air conditioning hardware?
  23. wheelguy
    wheelguy
    THANKS for all the tips and replies.
    I think I've got it fixed . got a tap in there and a helicoil >although the first couple of block threads were over sized when I got the motor it seems to be holding good.
    THANKS AGAIN, Joe
  24. HOTRODPRIMER
    HOTRODPRIMER
    I just saw this today and appreciate you letting me know, I received a PM from another gentleman from B.C. within 5 minutes of my post offering me the parts I needed, but thank you for the offer. HRP
