1966 Ford Small Block 289. This engine is all ready to be dropped in your ride and hit the gas. Standard bore Mild Cam Canton rear deep sump oil pan High volume oil pump Aluminum aftermarket 4 bbl intake. Vintage valve covers Holley Four Barrel Carb HEI distributor See picture for cross hatching in the cylinders so you can tell this engine is ready to go. **I have the front sump pan if needed. Willing to help box up the engine and prepare for shipping if needed. Send Text if interested 701.898.3117
