SBF/289 Is for 60's HotRods. Don't put WW on it!!!
Discussion in 'The Hokey Ass Message Board' started by MATACONCEPTS, Aug 12, 2013.
  1. Jaybird60
    Jaybird60
    This thread had all the makings of a turd, until Deuce Daddy Don polished that ****er into chrome with one post! Killer story Don!!!
  2. Kamp
    Kamp
    from Peoria, IL
    Technical? Cobra valve covers were available before cal custom, and they came with alternators in '65.
    My '31 has a '65 289 in it, Keystone valve covers, ManAFre 4x2 intake, and an old magneto... and not that I care what anyone thinks, but its as traditional as 95% of anything else you see.
  3. HOTRODPRIMER
    HOTRODPRIMER
    BS,,:mad:,check out all the 60's hot rod magazines,,always someone trying to skew history to what they think it is in their mind! :rolleyes: HRP
  4. Deuce Daddy Don
    Deuce Daddy Don
    Here's a bit more on original Cobra valve covers & 7 qt. oil pan.
    Look under the Cobra valve covers---If the letters read : Buddy L casting---These are the real thing!--Worth big bucks!
    Here's a Cobra catalog they gave when I bought the 260.
    Don't whine over these original prices!:D
  5. PackardV8
    PackardV8
    The first few Gen I Cobras had a 260" with the 289" HiPo solid lifter cam, aluminum 4-bbl and Borg-Warner T10. As mentioned, most were retro-fitted with the 289".
    The Sunbeam Tiger came along a few months later with a stock 2-bbl 164hp 260", but with the Ford toploader. The '67 Tigers, built after Mopar bought Rootes, got a 2-bbl 289". Because the Tiger was so easy to modify, it's rare to find a stocker. By the time I sold mine, it had a 250hp 302". When I bought it back twenty-five years later, it still had the same block and crank, but now with aluminum heads and about 300hp.
    jack vines
  6. MATACONCEPTS
    MATACONCEPTS
    I'm saying SBF & Wide White Walls don't match. It can be done, it just doesn't really match the era. Just a date thing. A real jalopy, might have white walls because of a lack of funds thing, but today with people paying $1000 for WWW's cause they want "The Look" & a lot of the Ford guys start off with a leftover Mustang Motor & build a HotRod around it. SBF HotRods shouldn't have WWW's like a Ford should have a Ford in it. Just My Opinion.
  7. hotroddon
    hotroddon
    the First Tiger had a 2 speed automatic and a recirculating ball steering box. It was only for proof of concept. The first production cars had a Borg Warner 4 speed due to Ford not being able to supply the Top Loader. Not sure how many got the BW T-10 trans, but it was at least 35 cars
  8. Gotgas
    Gotgas
    from DFW USA
    Huh? Wide whites on hot rods was still a popular look well into the SBF era.
  9. PackardV8
    PackardV8
    You want to get that technical, the first two prototypes were never badged, registered or called Tigers, just Alpines with an engine swap to prove a SBF would fit. The second modified Alpine got a rack and pinion steering.
    FWIW, the Tiger was always just a modified Alpine, built on the same ***embly line by the same guys. However, the Tiger Club guys hate, loathe and despise anyone who swaps his own SBF into an Alpine. The car can end up identical mechanically and in appearance, but they have a "Certified Inspection" which will prove whether the engine swap was done by Rootes or by an individual.
    jack vines
  10. arkiehotrods
    arkiehotrods
    221 introduced late '61 for '62 model year. 260 introduced mid-'62. 289 introduced '63. Lots of hot rods still wearing wider whitewalls at least through the HAMB cut off of '65.
    Historically, there were probably a number of people who put the then-new thin-wall Fords into white-walled hot rods. One can have a preference but to say it is historically incorrect is, well, historically incorrect! :)
  11. arkiehotrods
    arkiehotrods
    Not to mention the "Full House Cobra-354 HP!" blurb right there on the cover!
  12. VoodooTwin
    VoodooTwin
    from Noo Yawk
    I'm so lost in all of this. My head hurts.
  13. hotroddon
    hotroddon
    It is interesting and has been that way for years. When I had my Tiger in 1975 I remember guys saying things like the sub frames were beefed up on Tiger's, the front suspension pick up points had been relocated, things like this. From what I know the Rack & Pinion, bigger radiator, and the firewall to fender well struts and the dents in the inner fenders were the only real changes, other than badging and the lower rocker stinless trim. It seemed to me at the time it was to keep people from making Alpine V8's and to hold them in lower esteem. Kind of like what we used to call Porsche swaps - they weren't 911's they were 912-sixes.
    And on the T-10 trans cars, there were 56 I just found out.
  14. Kamp
    Kamp
    from Peoria, IL
    I'd have to agree ... this cover pretty much says it all.
    p.s. Why does he have a stop sign bolted to the fender? :rolleyes:
  15. And that's why the 'traditional' definition will never be fully settled.
  16. Francisco Plumbero
    Francisco Plumbero
    from il.
    It's fairly simple really.
    See..it's all do***ented in the type of fine publication as illustrated above.
    If...it graced the pages of the publication prior to a certain year it's acceptable to use in a rolling art form from that period. BTW, true form hotrodding did not die in 64, it's just that the current trend is to axe the date to keep pony cars out of hot rod sites. A car built to the hot rod format of 1969 is just as traditional as the evolution of hotrodding has evolved over time. We tend to accept that so long as the skills are high and the vibe is there.
    So in general if it was not in an early magazine or archive type in print you might not consider it correct for the form. If that's important to you.
  17. MATACONCEPTS
    MATACONCEPTS
    These are 60's White Walls & correct. They are not the 50's Wide White Walls I'm referring to, the FNG's are buying.
  18. somebody please posy bunnies with pancakes so this BS will at least be funny
  19. 49styleline
    49styleline
    It comes down to this, some guys get satisfaction from having there cars look how it would have in the 50s/60s ect.. And some guys get satisfaction from putting what they like in and or on there car.. I say if you have a 289 in your hot rod and you like the look of white walls then Use white walls.
  20. 49styleline
    49styleline
    ... Sounds to me like you just don't like FNGs
  21. hotroddon
    hotroddon
    Bunnies with Pancakes are not 60's traditional - these are
  22. Wide whites were still being used into the sixties, I know I was there!
  23. Big Mac
    Big Mac
    :rolleyes::rolleyes::rolleyes: This is getting stupid. I still don't see how you can do all this finger pointing at things that "aren't traditional" when you have a V6 in your 26 T. Help us all understand how that fit into your definition of true traditional?
  24. Don's Hot Rods
    Don's Hot Rods
    from florida
    Oh great, NOW you tell me !! :eek: Here I have been running around all these years with wide whites and a small block Ford, AND a gl*** body !! Boy am I embarr***ed !!!!!!!:eek::eek:
    Don
  25. EnglishBob
    EnglishBob
    Not the first 'drama seeking' thread 'Homie' has blessed us with.
  26. 2racer
    2racer
    <CITE>www.thefreedictionary.com/summery</CITE>
    sum·mer·y (s m-r) adj. Of, intended for, or suggesting summer. sum•mer•y (&#712;s&#652;m &#601; ri) adj. of, like, or appropriate for summer: a summery dress.
    Purists should know how to spell, and it is summery here....
  27. Hotrodhell35
    Hotrodhell35
    hahahahahahahaha
  28. go-twichy
    go-twichy
    i'm not sure if this will help, in fact i'm pretty sure it won't, but here's this. it just may save us all.
  29. Francisco Plumbero
    Francisco Plumbero
    from il.
    WWW wide wound waffle. Perfect.:D
  30. kracker36
    kracker36
    Wow, Now that I have read this---can you tell me what kind of tires to run in my flathead powered Model A? Maybe I should take the flathead out and put in a Vortec 350 with cracked between the seat Camel **** heads in it----then maybe after cutting the entire firewall out for the HEI distributor that is so big that it has its own gravity, I can have a traditional hot rod. MAybe even add yellow plug wires to ****e it up.
