sbf 302????? picssssss
Discussion in 'The Hokey Ass Message Board' started by lkydevil310, Mar 1, 2011.
  1. Zephyr3789
    Zephyr3789
    Here is a pic of the 302 we have in our Zephyr...
  2. josephs6392
    josephs6392
    My custom creation has a sbf in it. plenty of pics in my album on personal profile.
  3. chuckles0
    chuckles0
    Here's my 27'RPU w/a 302.
    *quote* Why would anyone & most everyone try to compare the 302 Ford with the SBC 327 & 350 ? Fords comparison motor would be the 351 Windsor ! It's not complicated 351 & 350 a correct match. Compare the 302 with the 305 SBC & now it's a correct match. Apples to Apples
    >>305 is a 'dog' compared to a 302! jmo.
  4. anymore pics
  5. 5wcoupehunter
    5wcoupehunter
    from FLORIDA
  6. Zephyr3789
    Zephyr3789
    Yeah, I have a ton of pictures. What do you want to see pictures of?
  7. JeffB2
    JeffB2
    from Phoenix,AZ
  8. What ever u can share different angles of the motor thanks
  9. Zephyr3789
    Zephyr3789
    Here are a few more pictures. I have surprising little pictures of the engine. It's a little hard to get different angles because the engine compartment is very narrow.
  10. HottRoddin29
    HottRoddin29
    Im putting a '875.0HO in my '29 truck. Check out my pics and ull see it all dressed up. And, the others are right, HP all depends on how much money you want to put into it. They are very reliable if treated well and wont let ya down. Kevin
  11. Baggs
    Baggs
    here is mine. firs one is what i started with two weeks ago. then the next two are what it looks like today after i put most of it together. then a close up of what i did with my valve covers. cant wait to hear it run!!
  12. lkydevils13
    lkydevils13
    baggs what valve covers are those
  13. Deuces
    Deuces
    Those look like Ford's 5.0L HO covers that came on the '87-'93 ****stangs... Made out of diecast aluminum..
  14. Zookeeper
    Zookeeper
    Ehh, not '87-'93 Mustang, and they don't even look like aluminum, judging from the stamped-steel rails. Anyway, here's my favorite SBF, and yes it's mine, and yes it's in a non-HAMB car.
  15. woodywagon1965r
    woodywagon1965r
    Friends dont let friends drive fords with chev power !!
    lovin my sbf 397 hp rear wheel hp never any regrets
  16. fbama73
    fbama73
    My OT daily driver is a 302. 160K miles, and still runs great.
  17. greazy john
    greazy john
    putting a 289 in my 48 f-1 have a gm front clip wondering what to do about oil pan as the front sump pan won't clear .....what have you others done for this ??? i know i am not the only one thats done this.. thanks john
    GREAZY HUBCAPZ CC EAST TENN
  18. Phillips
    Phillips
    Early broncos and some later trucks have rear sump pan, you will need the proper pump pickup as well. Search the HAMB I am certain there is a very detailed list.
    Here's one: http://www.jalopyjournal.com/forum/showthread.php?t=260466
  19. Baggs
    Baggs
    They are the stock covers that came on my motor. Which is out of a 86 tbird. Then I just mounted some customline script to them.
  20. shadams
    shadams
    I had a 302 in a Mazda pu when I was just out of high school and until I got all the bugs worked out it overheated to the point of shutting off.......EVERY time I drove it. And I drove the piss out of it. Still, after probably 50 serious overheats, the thing just kept on going. I fiannly got a big enough radiator for it and a good electric fan and all was well after that. I have a ton of respect for the 5.0
  21. LM14
    LM14
    from Iowa
    Go with the Ford, they run great. Here's the '64 289 with the smaller 5 bolt bellhousing in my '57.
    SPark
  22. CharlieLed
    CharlieLed
    Here's the 302/5.0 engine that is in my current 56 F100 project...a little more bling than most HAMB projects but it works for this truck.
  23. AnimalAin
    AnimalAin
    I've worn out a couple of 302s in my cars, and am currently running a 302 in my roadster and a 351W in my '40 coupe. Great motors, excellent parts availability, and they mate to the AOD transmission, which allows sporty gearing around town (3.90 and 4.57 gears), and lazy gearing on the highway (overall ratio in fourth gear 2.60 and 3.04).
  24. tedley
    tedley
    from canada
    adding some old big block valve covers and it's a different motor
  25. tjm73
    tjm73
    A roller cam 302 will make an easy 350-375+hp with just 9:1 compression and 87 pump gas. Plus they are fairly lightweight around 425-450 lbs with aluminum heads and intake.
  26. Nothing wrong with a 302 as that is what will be going in my 50.
    But I really like my 289!
  27. crankyf1
    crankyf1
    from Australia
    I've had a lot of 289 / 302 and 351w in a lot of different rides. built right they are a great motor with great dress up and go fast gear available. here a few pix of my latest build.
    Uploaded with ImageShack.us
  28. Is it reliable, come on man its a ford so of course it is, We have owned heaps of small block fords over the years in all sorts of cars and they run strong all day long, lighter than a chevy to.
  29. LilMo 56
    LilMo 56
    from Cleveland
    Can't come close to that blown beauty, but what the heck, here's what I have in the Morris. In it's 3rd year and other than twisting off the distributor gear and ****ing in a (wrong) intake gasket, it just goes.
