SBF Flywheel/Flexplate Question
Discussion in 'The Hokey Ass Message Board' started by newstranger, Oct 5, 2006.
  1. newstranger
    newstranger
    This one should be quick and easy for you Ford gurus out there and I know there's quite a few!
    First off, the motor/****** combo I'm asking about is the good ol' 289/C4.
    What I need to know is did Ford change anything regarding the flexplate over the years (teeth, weight, etc.)? Can I take a flexplate from a '65 mustang and bolt it into a '70's or '80's small block???
    I just want to know before I go to one of those "chain" stores and play the numbers game with the joker on the otherside of the counter...again.
    Thanks again everybody,
    newstranger
  2. squirrel
    they changed the balance about 1980
    and the size/tooth count also varied, it needs to match the bellhousing/trans case
  3. oldschoolstang
    oldschoolstang
    from texas
    The early models were 28 oz and have 157 teeth and the late models were 50 oz and had 164 teeth. Check the bolt spacing on your torque conerter also. check to make sure your ****** will bolt up to the motor also because if you have to switch your bellhousing it can be a real pain because ford made over 20 different bellhousings for the c4.
